horn access
How do you access the horn to replace it. Looked underneath and could not see any screws or bolts just top of horn. Could not see any brackets or wires either. Can it be accessed from above???? Very new to this any advice appreciated.
Mike |
what car do you have? oil cooler?
poof! gone |
Sorry I forgot it is an 87 coupe so yes oil cooler.
thanks, Mike |
You can get to them (although it's tight) by removing both the trim piece directly between the "accordian" and the wheel well and the "accordian" itself. Otherwise, you will need to pull out the oil cooler, which would be a HUGE pain in the arse.
