Failed again. I think this is the third set I have put in the car in the 6 or 7 years I have owned her. Last was about a year ago and included a new master cylinder. Has anyone else had this problem?
Is China exporting a hazard. There are two and they both failed and when they did it was intermittent. Got some real *****ing from fellow DE drivers and corner workers who reported it only to have them work when I came in and at the morning tech. Just changed the brake fluid and bled the brakes. Guess I'll have to do it again. More $$$$
Old Tee all 911s sold |
can't tell you how many i had to warranty, for free. they're all crap.
May not be the switch. Make sure the bulbs are getting a good ground in the sockets.
Mine gave me fits when i first got it. work one minute out the next.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thanks, but when you jumper across the plug and the brake lights light, well it ain't the bulb.
Didn't someone tear one apart and determine the contacts are too small for the current? The solution was new unburnt switches and a relay.
Happiest when Tinkering
Yep this one can't be blamed on china (too bad) the switches are a poor design from getgo and fail often. I bypassed them many years ago and installed a mechanical switch after my third change out failed.
What's Facebook?
LED bulbs might help as they typically reduce the current through the circuit.
I have never had an electrical failure of these switches, but have changed several (less than 2 years old) because brake fluid leaks from seal around the electrical terminals.
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
