Still Doin Time
Steel Braided Oil lines?
Looking to replace the hard tube (return?) from the spigot on the engine case to the flex line to tank. Also the (feed?)line from the tank to the engine oil cooler. Car is '85 3.2 with B&B exhaust.
Like to use steel braided lines with the correct fittings already installed. Does anyone know of a company that does/sells a kit or set-up? Thanks!
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Diss Member
Look for Earls or Aeroquip if you really want to do this. Stainless braid looks 'cool' and is indestructible but is generally a bad idea on something that will see a lot of miles.
The hoses act like bandsaw blades. I have seen normal vibration cause them cut through other hoses, paint and even completely through an aluminum panel. If you do put them in they can't touch anything except the fittings and the Adel clamps that hold them in place.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
