-   -   Have you pulled smog from a 930????? (http://forums.pelicanparts.com/porsche-911-technical-forum/259320-have-you-pulled-smog-930-a.html)
MobileWrks 01-04-2006 08:30 PM
Now, are you running into problems with the running condition.... do you regret it at the same time???? Im getting those calls to reinstall alot of smog emissions....:(
Emission 01-04-2006 11:58 PM
It runs better without smog equipment.
slow&rusty 01-05-2006 05:49 AM
I have pulled all my smog from my 930....my car runs perfectly without it and at the same cleans up the engine bay quite a bit....
Air injection system, pump and related hoses and lines and also the cat.
Here it is:
http://pic5.picturetrail.com/VOL86/5...6/97327854.jpg
Yasin
tas911 01-05-2006 07:07 AM
parts
pm sent
sand_man 01-05-2006 07:13 AM
I've heard from most that the car will pass WITHOUT it...unless it's some sort of visual inspection - i.e. the inspector knows what 930 smog equipment looks like and is checking to see if it's there and connected. Mine has all been removed. This stuff was really a shoddy "band-aid" at best!
john walker's workshop 01-05-2006 07:58 AM
if you have SC or other than stock cams, it's right at the edge sometimes. you may have to plug one injector to get the emissions down enough to pass.
carmad 01-05-2006 08:04 AM
Mine runs fine without smog equipment, definitely more power and runs cooler.
I put the the smog back on to pass emissions, mine passed with flying colors, the tech said it ran really clean.
im4duke 01-05-2006 09:40 AM
No smog stuff on mine except cat when emissions testing. Runs fine.
