Headlight Knob removal
How do I get the headlight knob off ( the knob you pull to activate the headlights)? Is the knob glued on or how is it fastened?
Thanks.
Matt '76 Porsche 911 with '78 3.0 SC engine '71 VW Bus '14 VW Passat (toddler hauler & wife approved ride) '03 Subaru Baja original yellow & silver |
With a jewelers screwdriver, remove the plastic face that has the picture of the headlight on it. Now remove the phillips head screw.
Done.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I popped the cover off, but all I see is a rounded end with threads. I'm struggling to get the rubber knob off now. How can I take it off without tearing the rubber?
On my 74', you just turn it CCW and it screws off.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Matt,
Could you take a picture for us if you haven't figured this out by now? Mine came apart just like Nine9six said, pop off the light emblem then unscrew the brass screw and your done. Maybe yours is different. Good luck and don't take any wires off the back without labeling and taking pictures.
Daniel 1988 Carrera Coupe (sold) 2012 Cayman |
Cool! I got the job done. I had to get a set of pliers to unscrew the round nut below where the screw was supposed to be. Overall, I got a chance to solder some wires, and know my ignition/light wires pretty well. Thank you so much!
I love happy endings like these...the "got it, thanks" threads...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Did you guys see a bulb in the knob?? I'm trying light up my fog light knob. Does the cover come off easy without scratching it?
j.p. |
No bulb in the Headlight knob. There should be a bulb in the fog light knob though. You might be able to pop off the face of the knob with a small screwdriver, but the way I got to the bulb was by crawling under the dash (which means taking a a few things apart) in order to get to the bulb.
Automotive Monomaniac
I get back pain just reading this thread... I hated working under my dash messing with my headlight switch (mine burnt out)... all twisted up and backwards under the wheel... awrg.
Glad you got it to work!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Matt:
Where's the bulb, in the knob or behind the dash? j.p. |
