Re: CIS to Carbs '74 - installation best practices
My stock fuel lines had a metric coupling fitting after they exited the tunnel in the Tranny area. I disconnected both couplings and brought the engine feed side to a hose shop where they removed the metric coupling and attached the coupling to aeroquip ss 6AN measured length lines. Not all hose shops have the contraption for doing this particular coupling. The metric fitting and 6AN fit together perfectly. Thx for the dizzy info.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Alright....
Warren, Can you go into more detail as to why the 5ES would be too hot? Is it because the CIS piston's are high dome? Because the engine is low compression? Thanks,
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
I can't add information on why the NGK 5ES might be too hot, but I can tell you that Richard Parr, who runs PMO and was of immense help in setting up my carb setup, recommended I switch to them in lieu of the Bosch plugs I had installed. He told me they would be fine in my motor (Elgin modified S cams, pmo's, 9.5 CR, bigger ports etc in a 3.7) and suggested that if I was nervous I should pull them every couple hundred miles and inspect carefully. NGK has a good web site showing you the difference between a plug which is too hot and one which is fine. I checked mine a couple of times and found them spot on. I stopped worrying.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Just reread my post above. 3.7 should be 2.7. Sorry for any confusion.
otherwise, you're among the lucky few who have been able to discuss carbs with Richard. with all due respect to others who comment where carbs are discussed I must humbly express that Richard is like no other in that realm. His position as a starting point must lead to satisfaction imo. imo it's a Carb eat MFI world.
Will do my best. And after only one glass of wine!
Agree though, Richard is THE guru.
