fuel pump replacement
I think the fuel pump on my 80 sc died. When I try to start it fires for a brief second as if cold strt is working and then quits. Lifting the sensor plate with the switch in run elicits nothing. I even removed cover plate over fuel pump and applied direct current to both terminals of fuel pump and got nothing. Is this an easy replacement? Thanks
Old 01-07-2006, 10:48 AM
Jubbie's Avatar
Yeah,
If you are getting power to the pump, but it does not go around, then it is replacement time. Wayne calls it a 2 out of 5 (where 5 is an engine rebuild). I have done mine but it is still in the back on the 74'. I would replace the fuel lines while you are down there.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 01-07-2006, 11:06 AM
use new brass O-rings with the new pump.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-07-2006, 01:21 PM
Lundy
Kirk Lundmark's Avatar
If you replace the fuel line, tie on a strong piece (I used about 25'+) of poly small diameter rope to the end of the old line to use as a guide when pulling the new line through. I did it myself while lying under the car. Feeding the new line in from the front and pulling with the rope from the back. I tied and duct taped the rope onto the new line to create a bullet head. I think this helped get the new line through with ease. I think in doing so, it could eliminate removal of the console for access.
Old 01-09-2006, 02:34 PM
