LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
Ptoscano's Avatar
Send a message via Yahoo to Ptoscano
Carrera 3.2 driving impressions: interesting
Driving impressions of a Porsche 911 Carrera 3.2.
I have driven hundreds of 911 3.2 and , one thing is certain. They all vary. I often read that you should buy one model or the other, but in my experience individual cars can vary so much that its unfair to say that one year is better than another.
Simply by the passage of time, use and maintenance each 911 will feel and perform differently.
These are fast becoming 'classic' cars - and rightly so. Yet this is a car that with a little bit of sympathy, one can use and enjoy daily.
Even though I drive all types and ages of modern 911, I still really enjoy a decent cross country drive in a 3.2. In no way is the performance and abilities of this car any embarrassment in today's use.
You can feel the build quality as soon as you step into the cabin. Although the sparse facia, floor hinged pedals may seem strange compared to a modern car, after a few hours behind the wheel it will all start to slot into place.
Below picture of a beautiful 1989 Porsche 911 Carrera 3.2 Sport Coupe that I drove 2200km in three days from Portugal to the UK in November 2002. And I got paid to do it!
These are not cars that you can simply jump in and tear around like in some modern hot hatch. It takes a good while to begin to understand how to make the most of their abilities, how to maximise the performance and how very good these cars are at covering the miles.
Compared to a modern sports car they feel remarkably comfortable on the road. This is largely due to the smaller wheels, with taller tyres and more compliant suspension than later 911.
Turn the ignition key and it is immediately obvious that this is a 'proper' 911. Because it is air cooled (no water jacket to deaden sound) you hear this glorious, special, metallic noise coming from behind that's unmistakeably Porsche.
The earlier models (1984 to 1986) all had a 915 type gearbox with reverse beneath 5th gear. There is no 'spring loading' to help ascertain between the 1st 2nd gear plane and the 3rd 4th gear so until you have a few miles under your belt the gearshift may seem a little uncertain. But persevere, take time with your shift, be positive. You must not rush through the gears, but keep gentle pressure on the lever until it snicks in place - hard to explain but easy with practise.
Later cars (1987 model to 1989) had an altogether easier to use gearbox (G50) type) with reverse beside 5th. The benefit is a stronger gearbox, capable of more misuse and easier to learn.
The later type is more valuable but in some ways I prefer the older models. Probably there is not much difference in performance but the 1984-86 models often seem to feel more vigorous, more responsive and probably were a little lighter too. With the later G50 type it added a little more weight and shifted more of the weight towards the rear.
Irrespective, if you find a good example of either type its a joy.
Cracking performance, with loads of torque from a beautiful sounding and super smooth motor. Surprising economy (due to tall gearing, low weight, small frontal area and low drag). There is no power steering and no abs brakes so all the skill is left with the driver. I like this, through the turns you can sense and feel everything the car does, the steering loads up and the faster you go the more physically demanding the steering becomes. The brakes are superb, of course you need some sensitivity in the wet, but the pedal has such great 'fee' that its easy to modulate the braking.
These are cars that reward a smooth, confident and skilled driver like few others. The flip side is that the clumsy or aggressive driver may find them a handful and would probably be better placed in a more modern car with more driver aids.
Go into the bends smoothly, get your braking done before you turn and gently squeeze the throttle at an earlier part of the turn, you will shoot out the turn with a smile on your face.
On a long distance these are pretty quiet and refined (if I have time I will post the story of my 2200km drive from Portugal to the U.K. in a 3.2). Top speed will be up towards 145mph - surely enough for most.
These cars feel so solid, so strong and unbreakable and to my mind are still superb to drive. No stress around town either, well maybe the clutch is a bit heavy and pas would be nice for parking.
All 911 of this age were built with galvanised bodies, very high quality components that ensure if you find a well kept example you can expect it to last and reward you.
Mechanically the cars were pretty simple, simple enough that a patient and thorough owner could maintain the car himself.
In all, if you are in the market for a special car, its unlikely that you would not enjoy owning one of these. Depreciation is slow, servicing not too bad, insurance low (with a classic car policy) and there are still some very good examples to be found.
Myth - every body you meet seems to have an opinion on the handling of a 911 'it goes off the road backwards' is the usual one. It's simply not accurate. Porsche are a very successful manufacturer - and successful racers. For years they have developed the 911 with the motor in the rear.
Driven skilfully these cars have very high performance levels, so for most 'normal' intelligent and mature drivers they are great. Of course with a big motor situated in the rear basic physics will eventually come in to play, so a 911 is not a car to take liberties with. Learn them gradually, learn how they best function, enjoy the challenge and the feeling of being connected directly to the machine. Ignore the bar stool experts
2012 XC90- wifey
2011 BMW 535I -Daily Driver
911/964 Widebody Cabriolet-Protosport Stage 1.5 Turbo
Old 01-09-2006, 11:51 AM
Yep, sounds like the '88 that I used to have. Best car I've ever had.
Old 01-09-2006, 12:37 PM
Martin3.2's Avatar
Well said !!
Martin
Old 01-09-2006, 12:54 PM
Send a message via AIM to johncarlos2003
Where's the picture of the car you mentioned in your lead off post? I ( and others im sure!) would love to see it! Great writing and you are correct!
Old 01-09-2006, 01:23 PM
carreraken's Avatar
Thumbs up
Nice write-up!
Ken
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 01-09-2006, 01:28 PM
I swear I've read this before somewhere. Do you write for a mag
Old 01-09-2006, 01:45 PM
reverse beside 5th in the G-50?
Beethoven
'88 911 Coupe
Old 01-09-2006, 02:04 PM
Ptoscano's Avatar
Not writtten by me , just thought it was an interesting article.
2012 XC90- wifey
Old 01-09-2006, 02:09 PM
JBO JBO is offline
...if you like the 3.2 you would be overjoyed driving an SC..
Old 01-09-2006, 02:13 PM
The Donkey's Avatar
beautiful, simply beautiful. So true.
Old 01-09-2006, 02:45 PM
911mot's Avatar
Here's another cut and paste jobby from http://www.netoffice.co.uk/carrera/drive.htm
Driving a Carrera 3.2 involves you like no other car. The following is an extract of a road test by Mike McCarthy (one of my favourite Porsche writers). The car on test is a 1985 Carrera 3.2 Sport Coupe -
"To say the 911 is all about performance is to state the absolute obvious - but what performance! What Car? managed a sensational 5.5secs to 60mph from a standstill, a mere 0.4secs slower than a Turbo! The same car then rocketed on to 100mph in 15.2secs, and 120mph in 22.6secs. Porsche claim a top speed of 152mph and few quibble with this - Porsche, unlike some manufacturers, tend to be rather conservative in their claims.
And, subjectively, the performance feels and sounds as exhilarating, as spine-tingling, as the figures suggest. From the moment you switch when the engine will idle with that characteristic "whoomph, whoomph" for a while, you know there's a beautifully made, jewel-like power house behind you. Nor is it all sound and fury, signifying nothing - though it must be said that in traffic jams there was an annoying unprogressiveness to the throttle. Floor it, however, and the muted growl from behind takes on a deeper bark, the exhaust at first overpowered by fan whine but as revs increase the harsh beat from the exhaust takesover, building up to a crescendo at the red line (reached almost alarmingly quickly in first and second) that is without doubt one most joyous noises to issue from any car currently in production. Could this be one of the reasons 911 owners keep coming back for more?
The 911 has a reputation for tricky handling near the limit. That may well be the case, but in some 400miles of travel in the test car it never put a foot wrong. The steering has a feel to it that puts you back about 20 years when rear-engined cars were all the vogue: it is light yet direct and, thanks to a lack of assistance, has superb feel.
Under 99 per cent of conditions the 911 displays mild understeer, changing to neutrality as power is applied. Deliberately entering a corner on a trailing throttle, or under braking, shows that the basic, unalterable dynamics of the 911 have been disguised but are still there: the tail starts to dictate the line through a corner. What has to be borne in mind is that in slippery conditions oversteer comes in at much lower speeds, The problem lies in the difference between grip in the dry and in the wet, which is more marked than in other, more conventional, cars.
Interior of my 3.2 Carrera
All the creature comforts a driver could ask for.
Obviously, for a car that requires a 'slow in, fast out' driving technique, brakes are important. Those on the 911 do all that is required of them: the only way we can see them being improved is the adoption of anti-lock braking.
Fat tyres and a stiff suspension setting are not the best way to achieve a smooth ride, and sure enough the 911 is not the best in this respect. Even on motorways there is some ripple, and potholes and roadworks can cause distinct thumps and jars. On the other hand it is far from soft and wallowy, a feature which many prefer".
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 01-09-2006, 03:00 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Obvious to even the most common observer. You can pry my Carrera from my cold, dead hands.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-09-2006, 03:13 PM
They look good too- and yeah, you can pry mine from my dead hands too.
Old 01-09-2006, 03:36 PM
Recreational User
porschenut's Avatar
Threads like this keep confirming my decision to hang on to my 3.2.
Old 01-09-2006, 03:37 PM
911mot's Avatar
Another good one:
1984 3.2 Carrera
Old 01-09-2006, 04:11 PM
911mot's Avatar
omg sorry dialup guys - it didnt resize!
1984 3.2 Carrera
Old 01-09-2006, 04:12 PM
LakeCleElum's Avatar
One should give credit to the author when using their articles!!!!!
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-09-2006, 04:13 PM
sweet97m3's Avatar
No kidding...frigging plaigerism...good writing or not...Euro mag write-up from last summer. Have the edition around here somewhere. Give me a break...
1986 911 Cabriolet
1991 BMW 535i
1991 BMW 325iC
2005 Chevy Tahoe Z71
2004 Mercedes C240 4Matic
1989 Ford F-150 (for the dirty work)
2004 New Holland TZ-24DA (kicks real grass!)
Old 01-09-2006, 05:48 PM
syncroid's Avatar
Okay. Shusch with all the praise for the 3.2 cars! You're gonna let the cat out of the bag for everyone.
Yeah I pretty much love mine too.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 01-09-2006, 06:02 PM
Wickd89's Avatar
3.2
Love my 3.2+G50. I test drove a ton of SCs and Carreras and unfortunately many of the older SC were not well maintained. I am sure a clean one would drive great!
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 01-09-2006, 07:14 PM
