Recaro Seat Experts
Hi I am looking to fit a recaro seat to my 912 69 LWB car .. now the seat when I went to fit it was too narrow. I also need a seat base I do understand that these are rare item to find and that it's out the question.
So I have found a base for a recaro from Mark at world wide classics and he has the latest seat bases for the the copy seats that he sells BUT they again are too narrow. So I would have to make a base for the sides ( eg flat plate ) about 2.5" wide . Bolt this down and then add the frame drill and tap new holes for the base then it will fit.. Now I am not sure if this will make me too high so has any one had this problem and can you give me any pic on how to over come it..
Too many cars too little time.. |
bump
hello, if no luck here you may try posting on the early s registry.
regards steve |
Re: Recaro Seat Experts
If you are tall and have a problem with headroom, then fabricate some angle iron brackets that attach to the original points to gain depth on the seat mounts. That's what I did with my '73 and gained legroom, too, by putting the crossrails back about 2" on the angle iron. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
I put Recaro SPG`s into my 65 912 SWB which we turned into an RSR replica.
Used standard Recaro mounting brackets, sliders from 81 Carerra and adaptor brackets, no problem at all.
Challenge your limits, don't limit your challenges 911 RSR Jagermeister replica (Sold) 1987 944 Turbo cup (Sold) |
