the symptoms of low compression?
All my spark plugs look good and the same. No one sticks out over anther. They all have good color. So all cylinder are burning good
Yet my engine has this rocking back and forth like its not balanced. Its at idle and you can feel the vibration through the car.
My question is could you have a cylincer or two with low enough compression as to get combustion and good spark plug coloration but cause the engine to vibrate as I described above?
1986 944 Turbo - Guards Red
Old 01-11-2006, 07:51 AM
change your plugs, wires, cap and rotor.
.... inspect the motor mounts too.
How many miles?
Oil burn rate?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 01-11-2006, 08:14 AM
Home of the Whopper
I had an engine with low compression in two cylinders. It ran rough at low RPM's and much better at high RPM's. Get a compression check that way you know for sure. A compression check will tell you if it's low, a leakdown test will tell you why it's low. Do a search, lots of info here. 3.2's are infamous for exhaust valve guide wear.
Good luck!
BK
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 01-11-2006, 08:20 AM
yeah, a compressin check is on the way after I put the vacuum gauge on it. However, I've never done compressin checks on a fuel injected engine. I imagine you pull the coil wire, take out all the plugs and open the throttle, but what do you do about the fuel - Im not sure I want the car dumping unburnt fuel into the system without it combusting.
BTW, I just replaced plugs and wires.
Old 01-11-2006, 08:31 AM
Friend of Warren
On your car you would just disconnect the DME relay located under the driver's seat. That takes care of spark and fuel.
Kurt V
Old 01-11-2006, 08:54 AM
Did you change cap/ rotor?
Did it have the symptom before?
Old 01-11-2006, 09:20 AM
no, I did not change the cap and rotor. But I looked at the underside of the cap and everything looked "ok".
Old 01-11-2006, 09:45 AM
Somatic Negative Optimist
Gunter's Avatar
Check the firing order and make sure the wires are going to the right cylinder and are connected to the plug.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-11-2006, 10:38 AM
I double checked all the connections. All were OK.
Old 01-11-2006, 11:07 AM
