-   -   how do you do a compression check on a fuel injected engine (http://forums.pelicanparts.com/porsche-911-technical-forum/260394-how-do-you-do-compression-check-fuel-injected-engine.html)
redcoupe86 01-11-2006 09:13 AM
I know you pull the plugs, pull the coil wire, open the throttle to WOT, but what do you do about the fuel?
redcoupe86 01-11-2006 09:15 AM
Nevermind Kurt V answered on another of my theads.
DW SD 01-11-2006 10:58 AM
For the archives: disconnect ECU from under the seat. It will still crank. OR disconnect the fuel pump (remove the fuse).
Doug
