rear ride height adjustment
I hate to ask a question that has been answered 100 times, but I used the search option and found no answer.
There is a clear formula about how much ride height change there is for every degree you move the spring plate. I am talking about the protractor on the spring plate method.
For example: move the spring plate 2 degrees, and it changes the ride height 1.5 inchs. That was just a example. Does anyone have the right answer. I have seen this published somewhere, but when you need it, you can't find it.
This is on a early car with non adjustable (eccentric bolt) spring plates.
Old 01-11-2006, 01:40 PM
look here -->
http://tech.rennlist.com/911/pdf/settings.pdf
its embedded in Thom fitzpatrick's ( widebody911) angle calculator
( http://rennlight.com/cgi-bin/spring.cgi )
- Wil
EDIT:
At static ride height ...1 degree change is 7-9 mm height change. however, this works only at the nominal angle when vehicle is statically at rest. Compare to a clock...the change from 2 to 4 o'clock is the same "angle" change as 5 to 7 o'clock...but 5 to 7 won't result in a ride height change.... 2 to 4 will.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-11-2006, 01:47 PM
911mot's Avatar
3. Now comes the fun part - setting the ride HEIGHT.
The Porsche Tech Spec book lists the trailing arm angle as 36deg30'-37deg with each 1 deg change in angle resulting in 8-9mm change in vehicle HEIGHT.
from http://www.pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 01-11-2006, 01:49 PM
Thanks guys!
Pelican hits a home run again!!
Old 01-11-2006, 01:51 PM
