Targa Leaking. What Part Is It?
Hello guys,
My targa is leaking water and getting the carpet drenched. I see it leaking from the side quarter windows on both sides. Does anyone know how to replace it and what part# it is? Thanks. |
The part you are talking about is the 911-Targa-Automobile, order one new unit.
It leaks, cabriolets leak too. They all do that. Don't drive it in the rain. |
Thanks.
If your seals and top are in good shape there are some adjustments that can be made that may help you.
The adjustments are outlined in the following document: http://radarhill.com/pdf_docs/targa_roof_repairs.pdf if the link does not work just PM me with your email address and I send you a copy of the file when I get home tonight. KC |
Thanks a million!
On page 6 of the Repair pdf document ... area #10 is critical area concerning window glass leaks, where a part called a Frame Connector resides ... Left is pn 911.542.065.41, Right is pn 911.542.066.41. The parts guy at Vasek Polak called it a 'squeegee' when I ordered a pair in 1978. Rivet is pn 900.056.003.20, and countersunk M5 x 8 screw is pn 900.270.050.07. The condition of the bonded rubber part of the squeegee is critical, and a tight, snug fit of the upper front leading edge of the window glass is important to eliminate window leaks!
Here are some screenshots ... part #15 is the culprit in the first, #12, #13 & #14 in the second: http://forums.pelicanparts.com/uploa...1137176262.jpg http://forums.pelicanparts.com/uploa...1137177257.jpg |
Wow, you guys gave me all i need. My targa leaks right where #15 is. Hopefully I can fix it.
Early S Man and the rest
Is there a crash course on how to install the corner connector #15 with the rivets Cordially VicSmileWavy |
jinnos
Can you chare your progres and repair step by step in #15 Corner Connector? Cordially VicSmileWavy |
Thank's for the fast reply . The problem I have is with the rivets that hold part #15 to the frame just the rivets , how to remove and re-instal or can I use the regular aluminum rivets(shorts). http://forums.pelicanparts.com/uploa...1179007554.jpg Cordially VicSmileWavy |
The culprit is item #13 the rivets how to remove and how to re-install
http://forums.pelicanparts.com/uploa...1179008358.jpg Very sorry but I cant up load the pisture , is Item #13 in the second page of the Exploded graphic Cordially VicSmileWavy |
Vic--
The existing rivets have to be drilled out and replaced with new ones upon reinstallation. |
You must have been pretty busy, checking out all those Targas and cabriolets. |
| All times are GMT -8. The time now is 04:59 AM. |
