you see Arthur...
jasonlee's Avatar
Brake lights
During the Vancouver Pelicans tour on Jan 7, 2006, I was informed that my brake lights don't work. I tested them when I got home, and they only come on when I push the brake pedal hard all the way down.
Any idea what the issue may be. Any help would be greatly apprecaited.
The car is a 82 (11 SC coupe.
Thanks,
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 01-10-2006, 11:32 AM
wcc wcc is offline
wcc's Avatar
Try a search, I found lots of info on this. I searched for "Brake Light Switch" For example this thread:
Brake light activation
Or try this link:
http://forums.pelicanparts.com/search.php?action=showresults&searchid=1693001&sortby=lastpost&sortorder=descending
Bill
997.2
Old 01-10-2006, 11:43 AM
scottb's Avatar
It's most likely the switches on the side of the master cylinder. When both go out, the brake lights don't work. Our host sells them. They're not expensive, and relatively easy to replace.
Good luck.
Scott
1984 Targa
Old 01-10-2006, 12:52 PM
you see Arthur...
jasonlee's Avatar
Thanks. That is probably the case. Looks like I will need to order some switches. How can I tell if they are 2 or 3 prong?
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 01-10-2006, 12:59 PM
Count the prongs on the switch. Probably will be two.
JR
Old 01-10-2006, 01:30 PM
you see Arthur...
jasonlee's Avatar
I guess that was pretty self explanitory. I must have bumped my head. Thanks again
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 01-10-2006, 01:43 PM
vash's Avatar
the SC needs the three prong. i just changed these the day before yesterday. the VW and our cars share the same part #. i got mine from a better local auto parts store. the back one is a beotch to get tooooo. it took a 15/16 standard socket with a funky elbow set up.
took 45 minutes, and i was wearing good jeans and shirt
poof! gone
Old 01-10-2006, 01:58 PM
Oh Haha's Avatar
When I replaced mine this past summer, I had my wife hold the brake pedal down as I changed the switches out. I lost just a bit of fluid and didn't have to bleed. WOOHOO!
Pacific Blue
Wayne
Old 01-10-2006, 02:42 PM
you see Arthur...
jasonlee's Avatar
thanks, guess I am going be ordering some pressure switches in the next da or so. Thanks again for the help
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 01-13-2006, 06:52 PM
