New shift coupler - loose?
I got "new" shift coupler from another source because of delivery times.
Is it "loose" from the factory? Between the two shift linkages and the transmission it moves about 1/8". But it doesn't twist at all. Is this factory?
Nick '85 Carrera |
Are you talking about a replacement coupler or just new bushings?
The replacement bushings I put in had the same loose fit and I ended up buying brass bushings from Pelican for a snug fit.
Tony G 2000 Boxster S |
I got a complete shift coupler from Porsche a few years back. It had the same "looseness" as you describe.
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Bummer, that's what I thought I was replacing in my bushing.
Nick '85 Carrera |
That is the exact reason I made my own out of Delrin.
All the new bushings have a little forward and back play. Bob
Bob Hutson |
The fore-aft clearance in the OEM bushings was "designed in" to reduce the transmission of noise and vibration into the car. It is not a defect in the bushings.
XLR8'd Member
Are you sure it is not the shaft only that is moving somewhere i (trany play)? just did my bushings and coupler and also thought mine was loose, but it was the normal play of 1/8" in the rod that conects the coupler to the transmission.
David (mechanic wanabe) 2002 Carrera 4S (replacement for an 84 coupe) 06 Acura CSX (wife beater) 05 Acura MDX (toy hauler) http://www.pelicanparts.com/gallery/david_84_911 |
Insert Tag Line HERE.....
one word,.. WEVO
Marc |
The OEM is purposely loose as it serves to function as a cheap universal joint. If it were made tighter, like using brass bushings in the same design...it's not the same as using a "pure and proper" universal...
See here for more--> Shift coupler for 915? - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
