New shift coupler - loose?
I got "new" shift coupler from another source because of delivery times.
Is it "loose" from the factory? Between the two shift linkages and the transmission it moves about 1/8". But it doesn't twist at all. Is this factory?
Nick
'85 Carrera
Old 01-15-2006, 07:21 AM
Are you talking about a replacement coupler or just new bushings?
The replacement bushings I put in had the same loose fit and I ended up buying brass bushings from Pelican for a snug fit.
Tony G
2000 Boxster S
Old 01-15-2006, 07:36 AM
Sigurd's Avatar
I got a complete shift coupler from Porsche a few years back. It had the same "looseness" as you describe.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 01-15-2006, 07:48 AM
Bummer, that's what I thought I was replacing in my bushing.
Nick
'85 Carrera
Old 01-15-2006, 08:20 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
That is the exact reason I made my own out of Delrin.
All the new bushings have a little forward and back play.
Bob
Bob Hutson
Old 01-15-2006, 08:46 AM
The fore-aft clearance in the OEM bushings was "designed in" to reduce the transmission of noise and vibration into the car. It is not a defect in the bushings.
Old 01-15-2006, 01:52 PM
XLR8'd Member
David 84 911's Avatar
Are you sure it is not the shaft only that is moving somewhere i (trany play)? just did my bushings and coupler and also thought mine was loose, but it was the normal play of 1/8" in the rod that conects the coupler to the transmission.
David (mechanic wanabe)
2002 Carrera 4S (replacement for an 84 coupe)
06 Acura CSX (wife beater)
05 Acura MDX (toy hauler)
http://www.pelicanparts.com/gallery/david_84_911
Old 01-15-2006, 03:43 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
one word,.. WEVO
Marc
Old 01-15-2006, 04:21 PM
The OEM is purposely loose as it serves to function as a cheap universal joint. If it were made tighter, like using brass bushings in the same design...it's not the same as using a "pure and proper" universal...
See here for more--> Shift coupler for 915?
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-16-2006, 08:55 AM
