-   -   ready to install, anything I should know (http://forums.pelicanparts.com/porsche-911-technical-forum/261128-ready-install-anything-i-should-know.html)
strupgolf 01-15-2006 03:40 PM
1986, 911. I'm getting ready to install new transmission mounts and I've searched, but is there anything I should know beforehand [problems} or special tools, or? Is the rear sway bar hard to remove? Thanks guys. SmileWavy
Kevin Stewart 01-15-2006 04:21 PM
I think you can just unbolt the side that goes under the tranny mount and pull it down, Im not sure your year car has a ground strap on that mount if it does clean and check it, you can probably just hold the trany in place with a jack and slide the crossmenber out, Kevin
