-   -   the truth about 3.2 turbo conversions (http://forums.pelicanparts.com/porsche-911-technical-forum/261318-truth-about-3-2-turbo-conversions.html)
raceman 01-16-2006 02:35 PM
l`ve driven it!! Finally got the craft out on the open road to test the various systems,log boost,fuel pressure and air/fuel ratios. The results? truly awesome amigos.Well worth the money. l`m using a .5 bar spring in the Tial wastegate to start off with and l`m seeing just under 7psi on the boost guage tell-tale which is about right.Fuel pressure tops out at approx. 44 psi and the wideband shows 12-14.My ex.temps are at about 1200' after running wide open and cyl.head temp shows maybe 200-300' at the most.The oil temps are on the cool side and in fact the car isn`t getting close to hot at all.That`s pretty low boost though so l don`t expect heat problems with the huge intercooler l have. l get full boost by 3000rpm if l`m wide open and the car is VERY fast. How fast? A lot faster.l will log some 0-60 times once my tranny loosens up a bit since it`s just been rebuilt and has only 1000 miles or so. pics to follow
ben parrish 01-16-2006 03:44 PM
Congrats.!! I hope to do the same in the future but I would prefer to buy a "kit" from someone who knows what they are doing. Keep us posted.
Ben
masraum 01-16-2006 03:56 PM
Yes, we need more info and stories. Since I no longer have my 3.2L or and 911 I have to live vicariously through people like you.
RickM 01-16-2006 04:21 PM
Race, great to hear. Which Tial did you go with? Also, whos BOV did you use? Thanks.
raceman 01-17-2006 02:43 PM
thanks amigos. l ended up with the 46mm Tial which is the priciest but it`s a bolt on replacement and looks great. The blow off valve l got is not up to par however and l`m looking for a replacement. l`ll get something brand name and proven to work,unlike what l have now which sounds like a bird fart. This conversion is not hard to do and uses available 930 parts,new or used. l understand l can boost as high as 10 psi with my current configuration ( 4-1 FMU and huge intercooler) perhaps even higher. l installed all the guages to allow me to safely find a reasonable maximum threshold and so far zero problems at .5bar. l`ve overboosted cars in the past though, before all the parts and info were available to us tuners.l think my system could be recreated for less then $5000.00 including buying the chip from Promotive.
bigrubberjeep 01-17-2006 02:52 PM
I have a couple of questions -
How many miles did the 3.2 have prior to the Turbo conversion?
Do you have a list of parts that you have used and the sources for them?
herman maire 01-17-2006 03:15 PM
Can't wait to see the pics.
Show the exhaust, intercooler ect..
I take it you are running stock 3.2 compression?
YermanCars 01-18-2006 11:37 AM
Your fuel pressure should be at 60 psi.
What turbo are you running?
raceman 01-19-2006 10:48 AM
l`ve got 94,000 miles on the car and it`s in mint shape with the engine never having been apart.The turbo is a split volute Garrett T4 60-1,.72 a/r which seems perfectly matched to the engine.l`ve bought or built several turbo cars and the lack of lag with this set up is incredible.l`m a little concerned with the fuel pressure readings though.l`m running a Vortech 4 -1 FMU which should at 7psi boost bump the fuel pressure 28lbs.The static fuel pressure is about 30 so l should see 58lbs but l see only about 43. The AFR`s look okay at 13-1 but l think l`d like to see lower at WOT and full boost.The fuel pump is new...
YermanCars 01-19-2006 10:56 AM
Yes you should read about 60psi on the fuel, be carefull you should be at 12:1on your a/f or you may blow it.
raceman 01-19-2006 01:51 PM
Yerman are you using a fuel pressure guage? and do you use the FMU (boost actuated rising rate FPR) because from talking to the tech support at Vortech what l`m seeing is normal. The fuel pressure builds UP TO 4-1,it is not at 4-1 until about 11psi of boost. l know Promotive uses a 3.82-1 rising rate unit so l should actually have a richer running system at WOT,10psi boost. The PLX wideband seems accurate but looking at the guages while wide open is somewhat tricky so l`ve seen readings down to 11-1.. l think...l really need a passenger to monitor while l drive. My exhaust temp/cyl head temps show no danger so far and even my oil temps are low at about 180'. l`ve got lots of testing still to do,like a pressure check of the entire intake from turbo outlet forward.l cap the turbo outlet and pressurize with the brake bleeder checking for leaks with ear and soapy water spray.Anyhow any help appreciated by other 3.2 turbo converters
WydRyd 06-25-2006 09:08 PM
raceman, how are you going with your Vortech 4:1 FMU?
Have you had a chance to verify your A/F readings under boost using this FMU?
My RR FPR is dead and I'm looking at replacing it with the Vortech one. I don't really want to spend USD$475 for a new Proto one :(
I'd be interested in your experiences with the Vortech unit.
raceman 06-26-2006 07:41 AM
hey Merv,good to hear from you.My tuning experience led me to a FULLY adjustable unit from BEGI/Cartech.This is what you need.Period.The adjustments are incredible:Gain,Rate of Gain,Boost onset.This unit allowed me to tune out the dreaded lean spot of"boost onset" that plagues users of other FMU`s. l spoke with Corky Bell several times before,during and after the tuning process.The car is an absolute rocket.The rears break loose in second gear if l mash it at 4k rpm.This car scares people.l`m running the Promotive chip with the most modest(safest) timing,the stage One.Later stages advance timing more so although my car runs out of steam near redline as a result of this l have no discernable detonation and cool running temps.Honestly,things couldn`t have turned out better.l`ll give you the rundown on all the operating systems if you like,l seem to have built a very safe balanced system. :)
sammyg2 06-26-2006 07:47 AM
There is a myth floating around that you have to hit very high boost numbers to make significant power, it just aint so.
As you have testified, .5 bar makes a huge difference. I can almost see the smile on your face from here ;)
I'm running .5 bar and love it.
My A/F ratio is rock steady at 12 to 1 under boost according to my LM-1, anything leaner than that would make me nervous.
jbrinkley 06-26-2006 08:26 AM
I like to see a build list and sources if you got the time.
WydRyd 06-26-2006 09:02 AM
Awesome stuff raceman. Well done! I may consider the BEGI/Cartech FMU if Proto don't come to the party and supply me a rebuild kit for my existing RR FPR. I'm trying to get away with a simple bolt-in fix, instead of tuning a whole new adjustable FMU on the dyno :confused: Sounds like you've done a good job of tuning the Cartech unit, so if I do go down that path, I may seek some tuning advice from you ;)
Are you running the Cartech FMU as a standalone unit, or in series with the OEM regulator?
Which model did you get? The 2025 or the MR2035?
The description for the MR unit is:
"Multi Role Regulators
The new Multi Role regulator from BEGi is designed to provide complete adjustability to your fuel injection pressure. The MR series takes all of the features found in our rising-rate regulators and adds the extra functionality and convenience of allowing you to adjust your base fuel pressure (the fuel pressure at fuel rail during idle conditions). This allows you to replace your factory fuel pressure regulator with a fully adjustable, easy to mount, single unit."
It seems like the 2025 unit is designed to be used in conjunction with the OEM regulator? Is that the case in your setup?
Thanks ;)
david.avery 06-26-2006 09:11 AM
Hmm... love to see some dyno #'s Raceman :) My car is running great, but it doesn't really scare anybody, it feels like a mellow 3.2 on the low end, and then crisply accelerates. I can't imagine it breaking my 255*17 tires free though, it hits softer than that.
raceman 06-26-2006 03:57 PM
hey amigos,thanks for the interest.Merv l have the 2025 and the factory FPR unit stays in place.The 2025 is plumbed into the fuel return line and l get my boost signal for it from a short pressure line plumbed to the T-body.l`ve got a .5bar spring in the 46mm Tial but l installed a MBC in the engine compartment that l`ve dialed to add another 1-2 lbs. As for the great power l seem to have over a Proto stage1 and l think there are a lot of reasons for that. My turbo is a bit different,more like their stage two unit.l have 930 headers,a trick exhaust,larger T-body and high power spark system.My intake uses the very minimum of silicon plumbing,instead using hard tubing to reduce lag.All boost reference lines are swell resistant accurate signals. l think my fuel system and guages allow fine tuning of power beyond what a kit can offer.l`d love to see dyno numbers too,everyone always does with Proto chipped cars...but l live in Santa Fe,New Mexico and there are no dynos here.l think Albq. may have one or two but l`m not sure about letting my car out of my hands to someone l don`t know.lf l ever need to dyno the car l`ll post the numbers,good or bad.l would say based on my personal experience and the comments from various HP experienced passengers that the car has over 300 Hp,maybe up to 350.lt`s A LOT faster then both the other Porsche turbos l`ve driven lately,a 78 and a 94 C2.One other thing to consider-the car is pretty light.Lots of CF and fiberglass...
WydRyd 06-26-2006 04:32 PM
Great to hear you're loving the boost :D
OK, now I understand how your FPR is installed. See, my Proto RR FPR replaces the OEM regulator, and is stand-alone.
If I replace it with a BEGi/Cartech unit, I may have to go with the MR2035 unit, which sets the base idle fuel pressure too. A bit more expensive than the 2025, but still cheaper than a replacement Proto unit :eek:
raceman 06-26-2006 11:12 PM
hey Merv,do you still have your stock FPR? or did Proto use it as a core?because you could reinstall it and go with the 2025. You`re going with twins turbos next? Just buy the guages like l did and tune it yourself.l bought my Cartech 2025 off Ebay for about $100.00 used and really shopped around for the rest of the kit.The only Proto part you need is the chip and if Steve W.gets into turbos we`ll all be set.
WydRyd 06-26-2006 11:23 PM
Nope, my OEM FPR was removed and I guess my ex-mechanic added it to his spare parts collection :eek: Looked everywhere for it to no avail :(
Or do you think I'm better off going with the MR2035 that does it all in the one FMU and trashing the Proto FPR?
What size fittings are the stock lines? 1/4 NPT or 1/8?
Which model Autometer A/F gauge did you buy, with the telltale?
greglepore 06-27-2006 07:15 AM
Merv-I believe the stock fittings are metric, but any good hydraulic shop should be able to either put npt fittings on your hoses or make up custom hoses using the existing fittings, new hoses and new crimps.
Question for you guys-what does Proto charge for their rebuild kit? What symptoms does a fpr in need of rebuild exhibit? Mine seems to "stick" occasionally-ie. sometimes, usually the first time I make a hard run into boost, the boost comes up but the power is off, then "whoosh", while subsequent hits seem fine-not sure if something is sticking or not.
Merv, given the location of the Proto fpr and the pain it is to install, I'd give serious consideration to mounting a new one in a more easily accessible place. You'll need to have at least 3 custom hoses made to do that, but it'd be worth it, given that the hoses are likely in need of replacement as a preventive deal anyway.
raceman 06-27-2006 08:21 AM
Proto modifies the stock Porsche FPR to be a boost sensitve rising rate unit at a claimed 3.82-1 ratio. lf Merv`s needs a rebuild already...l think the whole idea is clever and a great way to make tons of money for Proto but consider the dangers here. l really can`t see this unit being even close in reliability and build quality the the BEGI unit.This is Corky Bell we`re talking about here amigos.His FMU`s are the best available and are proven to do what`s needed of them,and more.The quality,reliability,ADJUSTABILITY,and warranty plus dependable tech support.Call BEGI,talk to Corky yourself like l did,several times.l`ll say it again though Merv,get the guages.Tuning took me three hours blasting through the gears on a remote desert hiway with some hand tools and an apprentice along to watch the guages for me.There is no way l could take in the tach,boost,fuel pressure and A/F ratio when l was caning it.That`s where a more sophisticated data logging system would be helpful but l just didn`t want the extra bother.lf this was a twin turbo Supra l`d go with the Japanese space program system but for this car plain guages are fine.l`ll get the model #`s of what l`ve installed if you want to follow suit with an affordable and simple set up like mine.My cockpit looks pretty cool right now :)
david.avery 06-27-2006 08:27 AM
Greg, a thought for you: There is a recent thread around about the traces in the air flow meter, that are commuted by some "wipers". They wear out and cause bad part throttle response. There is a tech article about moving them to work on fresh substrate that improves the throttle response (on my list to do). This could be amplifying our issues, mine seems a bit "sticky" too...
greglepore 06-27-2006 09:32 AM
The Protomotive unit I have isn't a modified Porsche unit by any stretch-its probably one of the "copies" Corky mentions, but it is a large billet alu fpr, not at all like the stock unit. I think I still have a stock unit somewhere.
David-Yeah, I know about the wiper; mine likely needs a tune (actually I keep a spare afm, may just swap that) but this isn't that, I don't think. The afm issue is usually off idle or consistent flat spots, this is more like the first time you hit real boost in say, 2nd gear, the engine seems to bog a bit, the rate of boost rise falls off, then POW, its back to normal with no change in throttle position. Feels very much to me like the fuel pressure isn't going up, then wham, it does. Need to get a cockpit fp gauge, I have one on the rail but its not useful for anything other than idle.
Raceman, yeah, I'd like to know what you're using.
WydRyd 06-27-2006 04:59 PM
Greg, I agree, the Proto FPR is a custom aluminium unit. It's huge! It's not a crimped OEM FPR.
Todd replied to my query and he said to remove the FPR, pull the top off and check that the diaphragm isn't stuck or torn and to also check that the piston moves up and down freely. If not, it may just need to be removed, cleaned and lubed.
The diapgragm is made of Viton material, about 0.060" thick. It's simply cut to size for their custom regulator.
Under NA driving conditions, it operates at 1:1 with a base pressure of 2.8bar (40psi). Under boost, the check-valve closes off and runs a 3.8:1 ratio with a base pressure of 2.8bar.
My fuel pressure gauge on the rail is showing me an idle pressure of 43psi!!! And I can also hear buzzing from what I think is the FPR under load. This typically means the diaphragm is torn.
Wouldn't surprise me, since the diaphragm in the fuel damper was torn too a short while back and pissing fuel into the vacuum port and flooding the engine :mad: Something's seriously gone wrong with the FPR I suspect :(
EDIT: Raceman, post some pics of your cockpit ;)
raceman 06-27-2006 10:43 PM
l`ll get some cockpit pics on here one day.My info about the modded Porsche FMU comes from T.knighton.According to him they take the stock Porsche unit and mod it to be rising rate.This procedure involves somewhat of a transformation,not just crimping the thing to raise the base pressure.lf the units you guys refer to mounts in the stock location then most likely at it`s core is a factory part :) or not,l`d have to see it to know.
Peppy57 06-30-2006 05:51 AM
raceman: Thanks for all the help on the door sills you sold me
amigo
