binding a-arms : I just start ...
So some days ago I realize that my A-arms binding (both side) as I start finally assembling front of the car I have seen that front end is to high so I start to going little down. But after reading treads about binding a-arms (by the way very interesting and lot of information about this problem could be find there)
I start to investigate what is my problem. So it looks that I have problem with front A-arms mountings. I even ask here about it and friend of us give me some advise (thanks Tony!) and I find those treads just about it. So I first spent 4 hours yesterday to solve problem -with left side it was not so difficult some typical washer and now I have positive effect - a-arms moving freely. Much more problematic is right side as I make several test with washer and let say nothing. When screw are not tight is OK but when I screw in - binding occur I spent some time to find spherical washer via Internet And finally have it : and even not so expensive 50 completes (female/male) around 50$ by the way I will give DIN number if somebody looking for it: 6319C and 6319D It will comes tomorrow so hope that it will work. Meantime I try to learn how it works... I will make some photos and post along with work progress. |
Tomy,
If that doesn't work, you could enlarge the bolt holes a little on the front mounting brackets with a dremel tool. That would give you some lateral movement to play with. I did this with my front suspension when the bolt was just maybe a mm out of line with the hole. My A-arms seem to be just about right now in terms of the amount of free play they have. |
good idea !! and simple ...
I'm curious to your solution, but couldn't follow without pictures. Let us know what you come up with.
Doug |
Finally I finished passenger side...!!! it takes me 3 nights of work with different washers etc.
So finally what I have: passenger side going on left side no washer between body and mount right side one washer front 3 washers And on all screws have one spherical washer and lock washer. And it no binding..... But the most helpful was sequence of turning of screws so I turn in first front screw to final torque 4,7 kmp (ca.45Nm) and side by side slowly left and right turn in a little one time left one time right and is OK now. |
| All times are GMT -8. The time now is 04:33 AM. |
