Testing O2 Sensor
My 86 Carerra is running unbelievably rich. Horrible gas mileage (even with my foot off the gas). I suspect the O2 sensor is going bad. Is there a way to test it before popping for a $220 test?
Thanks in advance britt |
02 sensor will not make your engine run that rich but an easy test: unplug it and see if it makes a difference.
Joe |
A Bosch generic replacement shouldn't be more than $60-$80. A search will yield lots more info.
Check the voltage there are 3 wires, black is the sensor signal which should fluctuate between 0.1 and 0.9 Vdc
If you connect in the harness it is the green wire. |
Don't just hang any old meter or test lamp on that O2 sensor wire, either!!! The test instrument MUST have 10.0 Megohms or greater input impedance ...
| All times are GMT -8. The time now is 01:59 PM. |
