safe's Avatar
28 year old front bushings...
I think I made the right decision to rebuild my suspension
Magnus
Old 12-12-2005, 10:25 AM
randywebb's Avatar
Wow - quite a pile of oxide powder...
Everybody with an old car should be made to view this...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-12-2005, 11:07 AM
safe's Avatar
Yes, kind of why I posted it is to say, "check out you t-bars and bushings, if they are unknown".
Magnus
Old 12-12-2005, 11:19 AM
Indeed, thats true and that picture perfectly illustrates how the bushings sag over time and permit the T-bar to rub.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-12-2005, 11:25 AM
Peter C2's Avatar
I just replaced mine and they looked exactly, if not worse than the pictures.
'71 911T => POC #388 GP
'89 928S4 5spd/LSD Baltic Blue Metallic Track Shark (SOLD)
'91 C2 Coupe Black/Black (SOLD)
Old 12-12-2005, 11:30 AM
wcc wcc is offline
wcc's Avatar
It doesn't look like it did any damage to the mount where the torsion bar rubbed. Good thing you caught that in time.
I was planning on doing this job too this winter and decided to hold off one more year. I think I'll revisit this project.
Bill
997.2
Old 12-12-2005, 11:33 AM
What bushings are you going to use for replacements? jerry
Old 12-12-2005, 07:13 PM
PS I also have a 77 targa
Old 12-12-2005, 07:14 PM
ianc's Avatar
OK, you got us hooked. Don't even think of not posting pics as you carry the project through,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 12-12-2005, 09:10 PM
safe's Avatar
Jerry: PolyBronze bushings front and rear, together with new 21/27mm SAW bars.
I will post more pictures as I get along but I'm only working on it on the weekends...
Magnus
Old 12-13-2005, 12:12 AM
durn for'ner
livi's Avatar
Ahh..crap !
And I was happy planning on just the turbo tie rods this winter.
Thanks, I guess..
BTW, you working together with Pål on your cars ?
Markus
Resident Fluffer
Carrera '85
Old 12-13-2005, 03:58 AM
Noel's Avatar
Mine looked very similar when I replaced mine a couple winters ago (No rust but evidence of rubbing on the torsion bar). Even a car with low miles will have this sagging issue.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 12-13-2005, 05:44 AM
safe's Avatar
Markus: No, Pål is unfortunately a long way from me.
Magnus
Old 12-13-2005, 06:06 AM
safe's Avatar
Annoying, I thought I had the gasket behind the front torsion bar adjuster. Can't find the little bastards....
When I called Porsche, they had to get it from Germany, if I'm lucky I they arrive Friday... I was hoping to complete the front next weekend...
Magnus
Old 12-13-2005, 06:11 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
OK, What's the down side to not replacing the front t bar bushings? I am sure my fronts have never been replaced. I did the rears a year ago.
Chris
73 911 E
Old 12-13-2005, 06:34 AM
safe's Avatar
I belive that when the tbars rub and rust, there is a big chance it can snap of.
If installing bigger bars it will only rub even more...
Magnus
Old 12-13-2005, 06:44 AM
If your adding larger t- bars, it doesn't hurt to enlarge the opening through the rack slightly, either by filing or dremel. The larger bars can hit these area's even with new bushings.
Old 12-13-2005, 06:50 AM
safe's Avatar
Even with rigid bushings like PolyBronze?
Magnus
Old 12-13-2005, 06:55 AM
Maybe not with those, but the rack was designed around 18mm bars and when you jump to 22-23mm the clearance gets tight, even with Polyurethane bushings.
Old 12-13-2005, 07:45 AM
Chuck Moreland's Avatar
Not to be contrary, but I've not seen a need to enlarge the hole.
The hole in the cross member is sized to accomodate the splined ends of the tbar which are about 24.6mm diameter. The hole is somewhat larger than that to allow the ends to pass.
The tbar is positioned within the hole by the adjuster cap, not the bushing. Movement of the tbar relative to the rack should be zero, since that end of the bar remains stationary.
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-13-2005, 08:31 AM
