Wer bremst verliert
What are these connections...
...under the steering column on a LHD 82SC. They appear to plug into relays, but I haven't gotten deep enough in my hood "deconstruction" to see what's on the other side...
Thanks!
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
These look like connector blocks, which connect items such as the ignition key switch to a wiring loom on the trunk side.
POKDUB Porsche 911E |
Wer bremst verliert
bump...anyone sure which is what?
thx
John,
I'm pretty sure one will trace back to the turn signal stalk.
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
no idea - try doing a continuity test while pulling fuses
on the newre schematics there will be some ID of what they are
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
The one on the right is for the ignition switch. The one in the middle is for the wiper switch. The one on the left is for the hi/low dimmer & turn signal switch. They are just multiplugs that continue the harness into the trunk.
Dan 2002 996 C4 Cab w/ Jake Raby 4.0 2024 Tacoma TRD Offroad 4x4 2003 Range Rover HSE |
