My intented path to EFI
this car will see light duty DEs and will serve mostly as a back road torcher. Please weigh in and be kind as I am a checkbook tech.
Project Type 930 Engine Stock crank, case, oil pump, etc. Case boat tailed (case airflow improvements) Carrillo rods 3.4L 7.5:1 pistons (final compression 7.2:1) retained Cylinders and heads have Nirostat fire rings (provides sealing at 1.2bar boost) 930 heads ported with stock valve sizes, but smaller 993 valve stem diameter on inlet valve (again airflow improvements) Valves were back cut for flow improvements Twin plug with Bosch silver plugs W4CS Aase springs and titanium retainers (pretty standard stuff) SC Cams Type 935 Individual Throttle bodies adapted to fit C2 Turbo Intercooler Stock fuel rails, regulator, damper, etc, stock fuel pressure BOSCH injectors, flow matched Very nice full bay intercooler (Bob Holcombe I believe) or C2 Turbo B&B Headers retained Fabspeed 4” Dual out exhaust Imagine Auto’s HF2 Turbo Powertech scavenge pump Tial BOV, Wastegate MoTeC M48 Pro or M600 Is an electronic boost controller necessary or will ECU control it ? Transmission Wevo Shifter Retain four speed transmission with new gear spacing retain big reds all around |
The Motec can be set up to control boost. You will have to get a boost solenoid, whomever dyno tunes the car can make a boost map
| All times are GMT -8. The time now is 02:06 PM. |
