-   -   91 C2 will only run on one coil (http://forums.pelicanparts.com/porsche-911-technical-forum/262395-91-c2-will-only-run-one-coil.html)
dougn1 01-22-2006 06:39 PM
my car started acting up the other day and got progressively worse untill it wont run at all.
some experimentation has yielded the following strange results
it runs smoothly if i drive the secondary distributor with the secondary coil. it runs albiet roughly when i drive the primary dist with the secondary coil
it runs smoothly when i drive the secondary dist with the primary coil. it wont start when i drive the primary dist with the primary coil
it wont start in the normal 2 dist/ 2 coil condition. (it tries to start but doesn't)
if i drive the coils with each others drivers, nothing happens in any condition....so there is a difference at least in the way the coils are driven
who really knows how this system works???
CBRacerX 01-22-2006 07:49 PM
Simple question, but is the belt broken? I realize the symptoms don't reflect this, unless you have the primary and secondary confused.
dougn1 01-22-2006 08:40 PM
no the belt's good
