degreeoff1's Avatar
67' 911 value...?
Got a line on a 67 911 complete but not running..if I could score this for $2500 would it be worth it...rust but not too much....
thanks
Josh
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 01-24-2006, 06:59 PM
304065's Avatar
How much rust? All the original parts there?
The most expensive SWB car is the one you get for free.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-24-2006, 07:03 PM
degreeoff1's Avatar
I'll know for certain on Saturday, what rust spots should I be most concerned with? I can weld well enough and plan on a restore if its a desirable year. Just ignant (hee hee) on 911's as I have been/will be a 914 guy.
thanks
Josh
Old 01-24-2006, 07:05 PM
304065's Avatar
Josh,
Well, the entire car. But mostly, the uprights that the rear of the front fenders bolt to, the longitudinals, the front pan, the floor pans, the torsion bar tube and the dogleg that leads up to the torsion bar tube. Let's not forget the front window frame and the sunroof channels, if the car is a sunroof car. Don't forget the smuggler's box and the forward parts of both footwells. Basically, you want to spend at least two hours poking this car with an icepick or screwdriver to ascertain the extent and severity of any rust.
Please note the VIN number, it begins with a "3" and also the original paint code from the drivers doorjamb between the hinges. While you are there, note the engine type number and the engine number, these are critical to figuring out whether to restore it, or to break it into pieces so that others might live. . .
The trouble with welding it up is you would need a pretty stout jig, like a Celette bench, to make sure everything is properly aligned. Search here for "Series900" to see how a true professional approaches the task.
A '67 911 normal may not be an economic proposition to restore. Which does not mean I'm telling you not to do it.
'81 R65
Old 01-24-2006, 07:14 PM
boxster03's Avatar
rust?
run
run very fast
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 01-24-2006, 08:43 PM
Alter Ego Racing
ErVikingo's Avatar
Originally posted by boxster03
rust?
run
run very fast
... to the bank
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 01-25-2006, 09:01 AM
dweymer's Avatar
Is this the red car in annapolis? That guy has been trying to sell it for a while now. The flares are very strange. The value is the alu case and trans.
Donnie
Currently Porsche-less.....
Old 01-25-2006, 10:02 AM
