tick tick ticking in my SC
I have an 80sc that has a constant ticking sound while in motion that increases in frequency as my speed increases.
I have read all the threads on this forum about ticking and it seems to usually be related to a brown wire with the spedo but I think it is different in my car as I still hear the sound while moving with the ignition off. When I drive along a wall or row of parked cars the sound is louder as it seems to bounce off the wall and sounds like it is coming from the front of the car. I have been told the brake rotors need to be resurfaced but can't imagine that they could be making this sound- Any ideas what it could be? I'm going to have the car on a lift tonight to look around. |
sure its not a nail or screwhead in your tire clicking as it hits the pavement?
__jfw834__ '90 C2 Cab - '12 Challenger RT "A woman is only a woman, but a car is an A-U-T-O-M-O-B-I-L-E!" |
I have looked a few times at the tires and have not been able to see anything although honestly have not lifted the car to get a complete look. The tires are bald so if anything it would have to be a screw/bolt that punctured the tire.
Adjusted the valves lately?
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
The motor has a fresh rebulid and then a valve adjustement about 2k miles ago.
Acquired Taste
exhaust leak?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
C V joints...check to see if there is any play back and forth. torn boots are a good give away
Registered abUser
cv joint or wheel bearing or brakes
cv's or wheel bearings..i third that.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
It would seem to be wheel related as the suond bounces back at you off walls. Lift the car and spin each wheel you may get the sound but it could be much quieter than when on the road.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
Hello
try the hand brake cable where it goes into the back of the wheel housing. It could have come out of the slot it fits in. The cable can rubb on the half shafts and make a ticking noise like you mention good luck |
Gon fix it with me hammer
handbrake cable , had that as well on mine
you can even feel it in the handbrake leaver if you put your hand on it while driving...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
thanks for the input- hopefully I can figure it out in a couple of hours-
So did you narrow it down? Inquiring minds want to know!
Andy 83 911SC Targa |
nope- we could not hear anything on the lift. The CV joints all looked good, the bearings were good and the brakes pads have plently of life left.
The tires were in even worse shape than I thought so i'm ordering new ones and will get the rotors resurfaced at that time. I didn't check the handbrake cable as I didn't know what to look for- is that only on the rear brakes? |
could it have been steel belts shinning through?
there was no steel, but the tire tread was not as deep in the middle and actually curved inwards. it was starting to feather also
I'm curious how you had the car moving with the ignition off.
'82 SC pewter metallic Time and Relative Dimension(s) in Space |
Yes only the rear brakes. look where the cable goes into the back plate on the wheel hubb. follow the cable and you will see if has come away, Have you tryed pulling up the hand brake? and dose the noise go away? Is the ticking coming from between the front seats?
83sc targa BBT |
The sound is gone! I didn't check last night because we didn't change anything but it's not there anymore. Could it have been a loose lug nut? |
