front oil pressure sender leak
I have a leak on the pulley end of the motor where the oil pressure sender connects to the case. (I thought the threads might be bad when I installed the sender.) Has anyone ever used a helicoil or something similar to fix such a problem. If so, where can I get a helicoil of this size and what size is it?
This is why one removes the block mounting the oil pressure sender out of the line and then after putting the block in a vise, one then removes the sender. See the below thread for a possible repair approach:
Stripped mag case where oil line go's |
