rfuerst911sc's Avatar
air filter fitment help needed
I found a set of billet K+N filter housings for my EFI project, these will mount on my 46mm TWM throttle bodies. Unfortunately they came with 6 inch tall filters and I need something shorter, more like the "standard" filter for carbs. Is there a filter element I can by at local auto parts stores that would fit? I guess I'm looking for a standard paper filter element that would fit Weber or Zenith carbs for like a 1973 car. I know I can buy the K+N filters but I would like to get a standard paper filter as I think they filter better. If you guys know of brand and part numbers that would be great. I'm trying to fire her up this weekend but need filters. Thanks
Old 01-27-2006, 04:45 PM
I did this research a few years ago. At the time I couldn't find any off-the-shelf replacement fiilter for the K&N-size housing. You'll have to settle for the K&N replacement or fabricate some foam filters to fit. (I did).
Sherwood
http://members.rennlist.org/911pcars
PS: Would be interested in a set of ITG filters?
Old 01-27-2006, 05:58 PM
Thanks Sherwood. I already had some ITG filters but because I have AC the passenger side filter wouldn't fit it was too long. The K+N I can shave the housing bottom plate for clearance. Guess I'll have to order the K+N filters.
Old 01-27-2006, 06:24 PM
