-   -   Fitting P201 to a generic engine stand (http://forums.pelicanparts.com/porsche-911-technical-forum/263176-fitting-p201-generic-engine-stand.html)
Joeaksa 01-29-2006 04:00 AM
Originally posted by techweenie
Yeah, I hear ya. I know it's "within tolerance" but I'm thinking about fabbing a triangular brace to the groove of the fan pulley just to make me sleep better at night. Magnesium doesn't really have that much memory or rigidity...
Totally agree. I want to go to sleep at night knowing that the engine on the stand will be in the same position the next morning. A bit of bracing goes a long way in this area, just make sure that it does not block you from rotating the engine in various positions.
JA
Trakrat 09-19-2017 12:50 PM
Originally Posted by Danskman (Post 2373844)
I mounted my P201 to an inexpensive Harbor Freight engine stand, and it worked fine. I rotated the engine many times on the stand without problems.
http://i12.photobucket.com/albums/a2...Academy022.jpg
Hi... how did you attach the yoke? The Harbor Freight stand I'm looking at is this one...
but I can't tell how the Yoke is supposed to attach to this engine stand??
http://forums.pelicanparts.com/uploa...1505850640.JPG
gtc 09-19-2017 01:46 PM
You remove the black brackets in that photo and slide the P201 in to the hole at the top of the stand. Keep the black tube handle for rotating the engine and preventing the 201 from sliding out.
Trakrat 09-19-2017 01:49 PM
perfect... thank you!
