Slippery Slope Victim
NY65912's Avatar
Electric to manual window conversion
With the diet plan of the SC DEmobile I would like to convert the windows from electric to crank.
Has anyone out there done this in an effort to save weight?
Yes, I did a search and came up with not much at all.
Mike²
1985 M491
Old 12-11-2005, 08:40 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Hi Mike, I have been thinking about going the other way - you want to exchange the parts??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 12-11-2005, 08:55 AM
Send a message via AIM to EPorsche
Mike
I was thinking the same thing. If you get anymore info please post it.
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 12-11-2005, 09:02 AM
fhernand's Avatar
I'm also interested in this project. I have a 67 that has electric windows and I'm wanting to go crank.
VINTAGE SPORTSCAR RESTORATIONS
www.vsrestorations.com
freddie@vsrestorations.com
Freddie Hernandez
(541) 535-3304
Old 12-11-2005, 10:05 AM
MOMO3.2's Avatar
There is some in depth info on this subject. I was thinking about doing the same thing for my 87. I recall reading that there ere a few different confiurations used across the same models so it is not easy to get a match. Moreover, the wrecking yards charge waaaay to much money for the parts. After reading other threads, I concluded that it just would not be worth it.
Mike
Old 12-11-2005, 10:08 AM
Mike,
before you pull the main harness [ the one that runs behind the dash] I would appreciate some pictures of where the end connectors get mounted to the chassis. I'm one of those that is planning to go the other way.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 12-11-2005, 10:14 AM
Kevin Stewart's Avatar
in general the crank and gears way more then an electric motor, Kevin
Old 12-11-2005, 10:35 AM
Crusty Conservative
silverc4s's Avatar
Was your 67 S equipped from the factory with electric windows? I was not aware until now that they were available as early as that.
My 1970 S has factory electrics, which I have been told was the second year available>>???
BTW: I think there is not much if any weight to be saved, unless you go to the "ST type" windows; plexi, with a strap to hold them at various points, no actual winding gears.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 12-11-2005, 10:54 AM
I swapped mine from electric to crank. I just pulled the door panels off and started at it. It only took a couple of hours figuring it out as I went along. I changed to RS lightweight door panels while I was doing it. I didn't weigh all the components but there is definately weight sabvings to be had. The crank does not weigh more than the electric motor , switches and wiring. The real weight savings comes down to the removal of the old door panels.
I've got my Sc down to 2387 lbs with a full tank of gas.
I say go for it, just don't leave any lose electrical conection lying around inside the door or dash
steve
1982 SC
Old 12-11-2005, 11:12 AM
sorry buddy the manual weighs more
Old 12-11-2005, 11:17 AM
here's how it came out
1982 SC
Old 12-11-2005, 11:18 AM
randywebb's Avatar
It's amazing that people are making assertions about the wt. savings or increase without posting the wts. and how they were derived (i.e. postal scale good; bath scale bad).
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-11-2005, 11:38 AM
hkspwrsche's Avatar
What kind of seats are those in the SC? I cant make out the name on them in the pic
thanks
Harold
Old 12-11-2005, 11:43 AM
There Tom Motorsports. I don't think their in business anymore.
Sorry for making assertions on weight without proper documentation. I just looked at the size of the pile of stuff that came out of the car verses the size of the pile of stuff going into the car and guessed that the bigger pile weighed more. Thanks Kevin Buddy for setting me straight! Sorry I'll be more careful before making wild assertions again
1982 SC
Old 12-11-2005, 12:09 PM
randywebb's Avatar
IF you still have the piles, you could weigh them. No one has posted the wts. (that I'm aware). But my comments were not directed at you specifically -- at this point, no one knows whether to believe Kevin, or you, or who...
Old 12-11-2005, 12:14 PM
NY65912's Avatar
Looks like I'll stay with the electrics. If weight savings is not appreciable than I don't see doing all the labor for a few oz's or a lb.
It would be great if someone knows the actual #'s.
Mike²
1985 M491
Old 12-11-2005, 12:23 PM
Crusty Conservative
silverc4s's Avatar
My (all) Lotus Europa(s) had electric windows - it MUST have been a weight saving for C Chapman to use them...
Bill
Old 12-11-2005, 12:43 PM
actualy there is a thread somewhere here about this and it had weights, im sorry but i believe your right it may have been a lb more then the crank, the real savings is in the door panel, but a rs panel is a rs panel, ill see if i can find the thread on the EXACT WEIGHTS, Kevin
Old 12-11-2005, 01:32 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you want to go as light as possible, try the strap method.
A strap with lots of grommeted holes is attached to the bottom of the window and a peg is placed conveniently on the inside of the window frame (top of the window pad).
You raise and lower the window by pulling on the strap to release it from the peg and let it down (or up) and re-peg the hole nearest to the height you want.
All you need are the rails for the glass (or Lexan) to slide in, and the bottom metal rail for the strap to attach to.
Method has been used in lots of older race cars.
Bob
Bob Hutson
Old 12-11-2005, 03:58 PM
randywebb's Avatar
I've posted some of my info on wts. of door components before, including a pie chart to give folks a feel for things. These are from the wt. database I maintain. But I don't think I have electric paraphenalia wts....
I gave Thom an earlier version of the database to put on his web page, Rennlight.com. Someday I'll get the other info into it and give that newer version to him...
But - the doors are not an important place to save wt. What you want to do is measure the distance form the wt. saved area to the roll center or the CG. That will tell the tale.
However, there is a strong cosmetic attraction for RS door panels....
Old 12-11-2005, 04:33 PM
