-   -   Ehaust studs and gaskets-replace? (http://forums.pelicanparts.com/porsche-911-technical-forum/263345-ehaust-studs-gaskets-replace.html)
SLO-BOB 01-28-2006 08:39 AM
Does one typically replace all of the exhaust studs and gaskets when re-installing/swapping the heat exchangers or do you use the old stuff? Typically I replace old hardware with new oem, but I'm not so sure about backing out all those studs.TIA
fly944 01-28-2006 08:49 AM
I wouldnt mess with the studs unless you have to. If you break some off you will not have fun. Gaskets should always be replaced.
