Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Question Rear bearing install! Help!
Well today i started the rear bearing removal on my 1980 911SC. After some swearing and a lot of heat the race finally came out. My question is now i have to reinstall the new bearing. I can press the bearing back into the knuckle easy. Is there a trick to press the hub(part with the lugs) in without destroying the bearing?
Nick...
1980 911 SC 3.0 Targa
1984 EL Camino SS
2003 Nissan Frontier SuperCharged
Old 01-30-2006, 04:20 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Formerly bb80sc
Vipergrün's Avatar
Freeze the bearing, heat the bearing sleeve, spray some silicone into the bearing sleeve, use the old bearing race as a 'drift' and gently tap the new one into place using a circular motion. Be sure to get the new bearing started square. Wear gloves, things will be hot, cold, and slippery. Do a search for 'home made bearing press' and you should find a few threads on making a cheap tool, which you can use to get the axle stub back in.
Cheers
-Brad
Porsche-less
2017 Mazda CX5
Old 01-30-2006, 04:24 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
