-   -   Eccentric...how far will it move? (http://forums.pelicanparts.com/porsche-911-technical-forum/263981-eccentric-how-far-will-move.html)
imcarthur 02-02-2006 05:47 AM
With 55/16 & 50/16 you have the 'standard' tires size. Your car is probably slightly nose down at 25" all around. Check on the door sill with an angle finder. Most will opt for 25.5" in the front which puts the rake around 1 degree.
Lowering increases camber & raising reduces. Change to toe is negligible.
Ian
