Introduction post
Hi-
First a picture of my ‘69T … ![]() The dim light makes the dirt and poor paint look a little better than poor… lots of patina here. I’ve had my car since 1988. I was really close to selling a few years ago but at the very last minute talked myself (and my wife) out of it. Using the search function - and more money than I care to think about - I recently completed (OK, started) about 30 or so of Wayne’s 101 projects. In various stages of completion right now: Suspension and steering: -Installed used Koni front struts from a ’73 with the 3.5” caliper spacing. New ball joints; cleaned out the old “open” Koni insert foot and plunger valves of deteriorated rubber and refilled with shock oil. -Tarret front ARB. -Turbo tierod kit and steering rack spacers. -Installed poly A-Arm bushings with spiral grease-groove and zerks. After many of hours of fitting (both OD and ID) the arms drop with their own weight with a tight fit. -New Koni rear shocks. -Neatrix bushings and SC adjustable springplates. I had to Dremel the end off of one of my spring plates to get it out. Days of PB blaster soaking and a BFH with multi-pry bars didn’t do it; the drill-a-hole-and-drive-it-out-with-a-drift didn’t work; a turnbuckle anchored to a concrete basement garage wall didn’t work; no way I was going to hook it up to an SUV and try to drive it off. -Tbars are stock. -6” Fuchs with 205/60s to replace my chromed steel wheels with skinny tires. Brakes: -Replaced solid disc, narrow M brakes with wide A Carrera fronts and wide M SC rear. Rebuilt calipers, new rotors, speed bleeders, pads, and SS flex lines. With hindsight, I wish I had searched more and just gone with OEM rubber on the flex lines. Ignition: -Installed Crane XR700 unit. -Replaced MSD 5 conventional unit with an MSD 6AL cd unit. Engine: -Replaced mounts. -Oil leak search and destroy mission. Wasn’t leaking bad, but it was annoying. Turbo lower valve covers, aluminum upper valve covers, new pressure switch, breather gasket, thermostat O-ring, crank pulley seal. -Pressure-fed tensioner update to replace the solid tensioners an ex-wrench installed. Transmission: This is where I am with the projects right now. What had started as a selector shaft and axle shaft seal replacement has turned into… -Update to my simplified differential with parts from a used 914 tranny. -New intermediate plate bearings, synchros, dog teeth, and sliders as needed. Thanks Pelicans for sharing your knowledge; and thanks Wayne for providing this forum. Cheers, Jim |
Nice! Gotta love an early car with steelies. My 69T was originally Light Ivory - before it was painted "resale red". Seeing yours makes me anxious to get the original color back on it. I bet you're glad you didn't sell!
"Rust never sleeps" |
Great looking car, I love it!
My first 911 was a '71T with steelies, I still miss it, even though it was a rust bucket. Never I mean Never get rid of it, you will always regret it if you do.
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold |
Used Up User
Welcome, Jim.
Great car. It's nice that you finally came 'out'. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
