-   -   3.2 Carrera Timing Curve (http://forums.pelicanparts.com/porsche-911-technical-forum/264438-3-2-carrera-timing-curve.html)
danielt 02-03-2006 06:24 AM
Can someone post the ignition timing curve from a 3.2L Carrera? I have rebuilt a big-bore 3.0L (98mm Pistions) and converted to EFI using SDS-EFI. The current timing curve I am using I think is causing it to jerk around at low RPM due to the rate of advance.
Thanks,
Daniel
Tim Polzin 02-03-2006 06:33 AM
That help?
http://www.911chips.com/ignition.htm
Tim
danielt 02-03-2006 07:11 AM
Great link. That should give a good starting point.
Thanks,
Daniel
