Talking how to make a small leak bigger
For a few weeks now I had been wondering the cause of a very small oil leak under my 84 Targa. After much deliberating on the challenges of replacing the oil return tubes I tried to wiggle one of them. I was surprised on how much play was in the tube, so I proceeded to wiggle and twist all the tubes. I thought i may have been lubricating the o rings? Well i successfully succeeded in making all my oil tubes leak and made my penny size drop of oil look like Kuwait.
Moral of the story if you have a leak you can't determine wiggle an oil tube.
Any last minute tips on oil return tube replacement appreciated.
I did have an idea to take a sawzall and cut the middle out of the tubes and then pull them out easily? That seems easier then crushing and pulling.
Happy trails
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 01-27-2006, 01:24 PM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
A pair or two of channel locks will crush them and they will pull right out. The expandable replacement tubes work well.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 01-27-2006, 01:34 PM
cycling has-been
bkreigsr's Avatar
sawzall scares me with all those metal filings floating around the oil system, especially downstream of the filter
bill k
Old 01-27-2006, 01:42 PM
I see Pelican has two brands of replacement tubes Laso and Domestic Aftermarkets there is a price difference. Anyone have any thoughts.
John thanks for th tip
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 01-27-2006, 01:44 PM
vash's Avatar
no sawsall. with a pair of pliers, they will resist like a beer can in your fist. "out" is about 100x easier than "in"
poof! gone
Old 01-27-2006, 01:50 PM
GOOD POINTS on the sawzall, I am sure glad I asked.
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 01-27-2006, 02:09 PM
Unregistered
sammyg2's Avatar
Dow corning 111 silicone grease is your friend, it will make it sooooo much easier. You "might" be able to do it with oil or regular grease on the o-rings, or you may invent new curse words trying.
I put mine in with 111 grease and did it by hand. If yours are a little more stubborn, try putting hose clamps on the tubes so you can have something to push against when trying to expand them.
I can't offer any advice on the two different types.
Old 01-27-2006, 02:19 PM
Is the Dow corning 11 grease available at autosupply stores?
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 01-27-2006, 02:31 PM
Dan in Pasadena's Avatar
Stupid questions coming, sorry.
What "locks" the tubes in their respective holes once expanded? The idea of a cheap hose clamp to get a bite on the tube while expanding them sounds great. Is the Dow Corning 111 grease available at my local Pep Boys, Kragen, NAPA, etc?
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 01-27-2006, 03:26 PM
Brad01mc's Avatar
Hi!
On my tubes, there is a cir-clip that locks in a channel "cut"/"notched" into the tube.
Like this...
http://www.pelicanparts.com/techarticles/911_oil_return_tube/911_oil_return_tube_pic7_big.JPG
Brad
'78 911 SC
'61 Mercedes 220b
'74 Westy 2.0
Old 01-27-2006, 03:42 PM
Detached Member
Hugh R's Avatar
Any o-ring silicon grease will be fine. I used the stuff I had laying around for my pool pumps. The tubes should be lubed so they slide in and out with two fingers before you crawl under the car. I had to remove my drivers side heat exchanger to get one tube in on my 84.
Hugh
Old 01-27-2006, 03:48 PM
DW SD's Avatar
Use SylGlide over at Napa. If not the same, it is similar. I used that on the o-rings and it worked like a charm. Couldn't believe how POORLY oil lubricant worked. So much so that I did come up with new swear words (as Sammy suggested).
Also, the trick with using the hose clamps to pry them into place worked well for me. You can do a search for tricks.
Doug
1971 RSR - interpretation
Old 01-27-2006, 03:57 PM
Serge,
Hop over to Rennlist and under 911 tech articles, you will find a particularly fine and well written instruction on how to replace the tubes.
It's written by
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 01-27-2006, 04:07 PM
Nine9six's Avatar
Cliff,
Is that experience speaking?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-27-2006, 06:01 PM
Some reports say use A/C "gaiter" springs in lieu of circlips to make life easier...sounds like a great idea....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-27-2006, 06:52 PM
Talking tubes out!
This was easy! it took all of 2 minutes. I guess now the fun begins? Good thing the parts aren't coming till Monday. Guess the wife will be pleased.
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 01-28-2006, 09:06 AM
450knotOffice's Avatar
Find the Dow Corning 111 that Sam recommends. Trust me on this one. He knows of what he speaks. Otherwise you will invent new curse words. Ask any of us who have done this how we know.
Old 01-28-2006, 11:26 PM
tuff going on the install of the tubes. I fought one so far and only half won. I got the tubes in but the clip isn't going to happen. Anyone know where to get the gaiter clip?
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 02-03-2006, 04:13 PM
