VDO Boost Guage connection question
What options do I have regarding the connection between the brake booster and the Boost guage? Has anyone pieced their own together? Any tips appreciated.
Vince, thanks for the link.
hey Rick,it`s a factory 930 part. A "T" one-way valve to keep boost out of the master and plumb a line to the boost guage. The part installs at the booster,not the gas pedal like the link infers.You will most likely need to access the guage from behind by some disassembly of the HVAC.This is a good time to convert your wipers to right hand parking.l bought my part from North Hollywood speedo but l`ll check it for a part number.lt`s really a simple procedure.
Rick, Thanks for the help. I was following up on the info yu gave me earlier.
I suppose these are the parts I'm looking for: http://forums.pelicanparts.com/uploa...1139074430.jpg |
that looks great Rick,just the thing.The cad plated metal fitting that you see on one end is a type that may not work with all boost guages but otherwise that`s the part.
