are 2. and 2.2 distributor the same
Sorry should know this but want to be sure.
do the 2.0 and 2.2 distributors physically interchange. I think the 2.0 is the small shaft, but do not know what the 2.2 is thanks in advance. brant
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
RETIRED
If they are both Bosch...yes....some 2.0s had the crappy Marelli dizzy....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Brant,
Yes, all 2.0 and 2.2 engine distributors will interchange. With the beginning of 2.4 production the shaft/bore increased to a nominal 30.0 mm.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Advance curves are different depending upon engine specs, for example 2.0 S vs, 2.2 T, aren't they?
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
thanks a ton everyone!
brant
