jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
'84 Turbo Speedo electric diagram or picture needed
Do any of you have a picture of the back side for the speedo of an '84 Turbo or the electric diagram?
The odometer (partial or total) is not working and while I'm very much sure that are the gears inside I find out that one of the electrical connections in the back is not pluged to anything. The speedo part works fine.
Jordi Riera
'84 930 (modified)
Old 02-04-2006, 03:43 PM
jriera's Avatar
Morning bump .
Please .....
Jordi Riera
'84 930 (modified)
Old 02-05-2006, 07:04 AM
Jordi;
If your speedo works the problem has to be internal, don't you think? Tell me what wires you have attached to the speedometer and what color the loose one is and I'll try to tell you where it should go. There are too many variations in color code from year to year for me to be sure of what you have.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 02-05-2006, 02:03 PM
jriera's Avatar
Thanks JR, I agree that the problem must be the gears as usual.
Just puzzled by having one pin on the back not connected (and no cables 'floating'/loose around), maybe is the way it is ....
Jordi Riera
'84 930 (modified)
Old 02-05-2006, 05:57 PM
