Zenith Carb questions...
Currently rebuilding my carbs, have two questions...
1) waynes book talks about adjusting the floats, but his book is on webers, does this also have to be done on the zeniths? and if so what is the procedure, same?
2) the first carb is took apart only had two emulsion tubes instead of three, the other carb had three, is this how it is suppose to be or do you think one was lost on a previous rebuild by someone else? how would not having three hurt the way the engine runs?
sorry about all the questions but if im not going to do it right i shouldnt do it at all.
thanks.
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 02-07-2006, 06:47 PM
You should have 3 emulsion tubes for each carb. I would think the car would run poorly without an emulsion tube in a carb. It is part of the main jet circuit and is instrumental in forming the air/fuel mixture. You may not notice it at idle because the main jets aren't use when idling. Hope this helps.
69 911 2.3Ez
85 928S
Old 02-08-2006, 04:34 PM
got the car recently, had to do some work to the fuel system, when i did get it running it did run terrible, thats why im doing the carb and engine rebuilds. when i noticed the tube missing i to thought that may be part of my problem, i have found a few problems left from the PO when he must have rebuilt them years ago. im trying to find a source for a emulsion tube, have any suggestions?
1970 911t
Old 02-08-2006, 06:05 PM
Actually as bad as they be on engine rebuids Motormeister has lots of Zenith parts. I got different size jets and venturis from them. The venturis are webers but they have an adapter gasket that lets the weber venturis fit the zeniths. They have a big website. Otherwise you can purchase used webers or new PMO's.
69 911 2.3Ez
85 928S
Old 02-08-2006, 08:43 PM
bjmullan's Avatar
We have a Zenith expert at our UK DDK website and he has his own website dedicated to the Zenith carb with diagrams etc. Check out his site it maybe of help (big thanks to Gary!)
http://www.gary.suggate.dsl.pipex.com/
Brendan
1969 911T
Old 02-10-2006, 12:51 PM
I have some spare emulsion tubes.. ajkroll@aol.com
Old 02-10-2006, 01:12 PM
"Currently rebuilding my carbs, have two questions...
1) waynes book talks about adjusting the floats, but his book is on webers, does this also have to be done on the zeniths? and if so what is the procedure, same?"
I think you use paper washers to shim the fuel inlets in order to set the float bowls. The more washers you use, the more fuel in the bowls. You will also need a float bowl tool to measure the amount of fuel in the bowls. The Zenith floats are very different from the webers.
Alan
206AA
1979 911 SC Couple
Old 02-10-2006, 08:10 PM
As I recall the same float level tool can be used on Webers and Zeniths. This is the tool that screws in at the bottom of the float bowl so you can see the fuel level.
The link from bjmullan (above) has copies of the factory manual which tell how to adjust the level.
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 02-10-2006, 08:51 PM
