<insert witty title here>
bilstein roll pin strength
I'm at it again, trying to get the [insert choice expletive here] roll pin out of my front right bilstein shock. I've so far gone through pretty much every punch available to mankind, and broken them all. I've applied heat, beat it with a sledge hammer, you name it, the bastard ain't coming out. I've now got two different chunks of punch stuck inside there, and that's after getting a broken awl tip out already.
I've come to the conclusion that it's time to pay a shop to do this. I've already been at it for 3 (very long) days. Question is, is it safe the drive the car with the roll pin beat to *****? I'd be going about 150km (car is in storage for the winter in the boonies) to the shop I always go to. I could take it someplace closer, but I'm not sure if I trust them. I could have it towed, but that's not cheap. My thoughts are that it *should* be safe, considering I can't get the f&^cker out to save my life, and there's extra chunks of steel in there, but I'd like a second (or more) opinion. Thanks! Chris
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Alii&Maui
When I did mine I pounded the pin so much that it started to mushroom the end. I ended up drilling the pin.
I started with the smallest bit that would not fall thru the roll pin hole and went up in size. The thing is I just drilled about half the length of the pin and punched the thing right out. (I guess I loosened the grip of the pin) I destroyed about 10 drill bits, but I got it out
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
The problem here is that there are pieces of broken punch inside the roll pin, which I can't drill. I used a cobalt bit on it (hardest, toughest bit I could find) and that barely made a dimple in the punch piece.
Any ideas?
cycling has-been
just did this job on sat. your car should be okay to drive for the one-time 150km ride. all the roll pin does is keep the fixed end of the insert planted on the a-arm. worse case scenerio is that it moves up in the tube a bit when you hit a bump, then will expand back down to the seat on the rebound. try to avoid any potholes or running over any speed bumps or curbs.
here's how I finally got mine out: '7mm roll pin punch' from mcmaster-carr, bf hammer from home depot (4lb stanley) and a bunch of kroil applied over the last 4 weeks. new poll pins are available from Bilstein by phone in the west coast office, ask for 'small parts'
73 911T MFI, 76 912E, 77 Turbo Carrera |
I removed mine the other weekend as well. I used a finish punch for finishing nails. I hit the pointed end. I used a short handled sledge, was probably 4-6 pounds. The pins were stubborn at first, but then broke free and slid halfway out. I was able to grab the exposed end with a vice grip and turned and pulled.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Thanks, guys. In searching on this board, I've noticed a lot of people talking about having to buy new roll pins directly from Bilstein, or other sources. The new inserts I bought from Pelican came with new roll pins in the box. Is this a new practice?
I bought my shocks back in November, but sat on them until the last two weekends. Mine came with pins as well. The wrong end of the finish punch was about the same diameter as the pin. Once the pin breaks free it'll slide out with much less force. Wail on it a bit more!
Dave
cycling has-been
oh yeah, I also bought a Drill Doctor in case I ran into the problems you are going thru. (best thing since liquid Prell)
here's the thread I started when I was having problems roll pin won't budge
Try hammering it out with an air chisel.
