throttle response?
I have a 1978sc. Is it normal for you to rev the engine and the throttle to hang up some before returning to idle. Also inbetween shifts is it normal for the revs to fall slowly? Is there a way to get them to drop off more like a modern car or is this something that I have to live with? thanks Jim this is a cis fuel injected system.
Old 02-05-2006, 12:55 PM
Designer King
Paulporsche's Avatar
That is normal/correct. You can eliminate this by plugging the top vacuum line to your decel valve, or adjust it by turning the adjustment on the top of the valve.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-05-2006, 12:59 PM
jwetering's Avatar
Hey that's right...I remember bypassing my decel valve back when I first got my car. Seems like a long time ago but it has only been nine years. Man!
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 02-05-2006, 05:45 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Doesn't a heavy flywheel affect this, also?
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 02-05-2006, 05:51 PM
Interesting. I always thought that flywheel weight changes would have the biggest influence. How much of a change will this yield and are there any risks or downsides to it? How does it compare to lightening the flywheel?
This is something I've been wondering about. Several of the 911s I've driven had what I think of as somewhat sluggish throttle response and I'd be interested in knowing how that can be addressed without building a really expensive, really high strung race engine.
Old 02-05-2006, 06:28 PM
deceleration valves get old and may need attention eventually. I plugged it when I ran CIS. It's a smog contraption.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-05-2006, 08:05 PM
It's very easy to kill the throttle response on a DME 3.2 engine. All you have to do is have the mixture set too rich, beyond the range the 02 sensor can compensate.
To make things worse, the mixture control on the AFM is impossible to access and highly inadequate when compared to CIS.
Joe
Old 02-06-2006, 12:39 AM
I don't have to worry about smog, So how do I eliminate it? Does any one have any pictures of what I have to do?
Old 02-06-2006, 07:39 AM
can you install pistons, cams, & carbs ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-06-2006, 04:07 PM
Do you really want to devalue your 911 with these mods?
Joe
Old 02-06-2006, 04:19 PM
"devalue" is a subjective opinion.
One big hp pelican member wanted to buy my car if I ever sell it. Another P shop owner also wants 1st crack at it.
Either you like personalized 911's or you don't. Everybody's correct.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-06-2006, 05:14 PM
