Rolon's Avatar
oil presure
Hi every body, my car oil pressure is very low when the car is on idle. I wounder what is the range of the oil pressure at that speed.
thanks in advance
A L Rolon
Old 02-04-2006, 09:19 PM
kqw kqw is offline
At Idle, the oil pressure gauge will read at 1 bar or less. Normal.
The Fox
Carrera
Old 02-04-2006, 10:07 PM
Now in 993 land ...
aigel's Avatar
What kqw said. If you don't like it, you can put the updated oil restrictors on the cam housings and you will bring it up by a bar. I did that and like it better. You can find the part here on PP, it is cheap too!
George
81 SC (sold)
Old 02-04-2006, 11:45 PM
Rolon's Avatar
what I have to do, to do do the upgrade.I get nerve because look to low.
A L Rolon
Old 02-05-2006, 07:03 AM
I agree with Rolon I have a hard time waiting for the oil pressure to rise.
1984 Targa SOLD
996 C4
Dodge Ram
1952 Ford F-1
Old 02-05-2006, 07:17 AM
Higher pressure = less flow. Since these engines are significantly oil cooled, if the low pressure warning is not coming on and you're not using oil I wouldn't screw with it.
Old 02-05-2006, 07:30 AM
Camshaft Housing Oil Pressure Restrictors
There's enough here to make your head spin.
Old 02-05-2006, 07:34 AM
What oil do you use?
I use 10W40 in my 2.0 1969 911T, and my oil pressure is normaly = RDM/1000: ad idle (1000 rdm) the oil pressure is 1 ad 2000 RDM it is 2 and so on
I think that if you use a 0W40 oil you will have less oil pressure
Old 02-05-2006, 07:37 AM
Rolon's Avatar
I use 10w40
A L Rolon
Old 02-05-2006, 09:58 AM
Now in 993 land ...
aigel's Avatar
You should switch to 20W50. That will help! And without starting an oil discussion thread, many people use and recommend 20W50.
George
81 SC (sold)
Old 02-05-2006, 06:26 PM
Rolon's Avatar
Thanks for everything
A L Rolon
Old 02-06-2006, 05:59 PM
