-   -   A/C compressor clutch replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/265022-c-compressor-clutch-replacement.html)
bcr4d 02-06-2006 01:48 PM
I just received my a/c comrpressor clutch and was wondering can the clutch be replaced while the compressor is still in the car?:confused:
scottb 02-06-2006 02:26 PM
What year is your car? Assuming it's an 84+ with the Nippondenso compressor, here's a Tech Article that might be helpful. From the description in the article, it sure sounds like you can remove the clutch while the compressor is still in the car. Maybe our resident a/c guru, Jim Sims, will chime in. If he does, take his advice to the bank -- it's gold!
Good luck.
bcr4d 02-06-2006 05:23 PM
reply
car is a 88.
scottb 02-06-2006 05:27 PM
Re: reply
Originally posted by bcr4d
car is a 88.
Then it's got the Nippondenso compressor. From what the Tech Article says, it sure sounds like you can remove the clutch without removing the compressor from the car.
bcr4d 02-06-2006 05:33 PM
reply
I'll let you guys know how it turns out. Thanks again.
