3.2 liter Seat Up/Down Switches Out
The driver's side seat of my 88 3.2 Carerra Coupe recently had the up/down switches go out. This has been confirmed (Can't hear the motor when the up/down buttons are depressed). I don't have a repair manual yet, on order, and was thinking of ordering the switches and swapping them out this week. Not a big deal -- the seat position is just slightly off -- but I'd like to fix it if it can be done quickly.
Am I going to run into issues with removing the seat, switches, etc.? Seems it would be straight forward. Or should I wait to get my manual? I'm fairly mechanical but I haven't ever removed seats from this car and want to make sure I'll be able to remount them correctly. Appreciate any help. Thanks a bunch!
Ed 88 911 Carrera Coupe Last edited by EMJ; 02-06-2006 at 10:54 AM.. |
Ed,
I am no expert either, but the seat removal and switch work should be a breeze. I have pulled my seats a few times with no issues. Also, the switch assemblies are easy to access etc. I think if you have the new switch in hand, you can't go wrong. Heck, even if you do, this board will save you ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
New task Ed now that the 911's not dying anymore? Congratulations on the last repair. This ones fairly easy. Just takes some manual dexterity.
Taking the seats out and putting them back in is the easy part. Its fixing the dang switch and getting it back in that was a pain for me. I did not buy new switches since a search here had enough information for me to try it with success I might add. Someone posted some great pics of repairing the switches. The contacts corrode and just need to be cleaned. Do a search. Lots will show up. I'll look to see what I saved on this and post it later. LOL
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
MAGA
Just be careful when disassembling the switches as the interal parts tend to go everywhere when you take the switch apart for contact cleaning.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Hey, cbeers, Tom, Thanks for the help.
And cbeers, so true about this board. Tom (jtratza), and a few others just helped me solve an intermittent shut-off problem that was driving me and my mechanics nuts for about 5 weeks. This board helped me solve the problem in 3 days! She's now running great! DME cracked joints that needed to be soldered were the ultimate problem. I could probably live with the seat positioning as it currently is, but I figure if I could fix the issue easily, maybe I should just tackle it. Tom, thanks for the tip on the corroded contacts. I think I'll check those before I purchase new switches. I'll do a quick search. Maybe I won't have to replace the switches after all!
Ed 88 911 Carrera Coupe |
Will do. Thanks, Tim.
I have had 2 seat switches fail; the first time I took the seat out but second time out I simply released enough cable (cut the cable ties under the seat) for the switch to be pulled clear from the seat by a couple of inches. From there I desoldered the failed switch and then soldered back the new switch.
A 40-50 min job cut down to 15-20. However if you are not great with a soldering iron, the of course go with removal of seat and replace the entire switch and wire harness that it is shipped with.
1987 911 midnight blue, euro spec, 7&8 Fuchs, SW chip 2003 Fiat Multipla Don't blow a seal......literally. |
I'm sure I could get my hands on one. Definitely sounds like the quickest way to go if the switches need to be replaced and it isn't that the connectors are corroded.
Ed 88 911 Carrera Coupe Last edited by EMJ; 02-06-2006 at 01:47 PM.. |
you can also use crimp style red butt connectors. cut the wires close to the old switch and a couple of inches away from the new switch to give yourself a bit more room to work.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 02-06-2006 at 02:13 PM.. |
John's idea works great (Which is typical of John's recommendations). I used the crimp style and it made the job much easier. I tried to solder the connections and gave up. Maybe its because I torched my thumb one year taking a shot at home plumbing some laundry room pipes at midnight and beers one year.
