help from the electrical/fuse gods
I have an 83sc 911, Well i screwed the pooch on this one....I placed a crow bar under the trunk while i was working on car..Well i then took the car for a drive down the road without closing the trunk fully and while i drove the crow bar touched, my guess is the open fuse box with poss. a ground(trunk). Well i then saw a spark from fuse area and another from my steering column, then my headlights blew. My wipers dont work,rear brake lights either..I have no fuses (21)blown, not sure bout others but dont think there bad either i switched them around too and checked the rear ones too....WHERE ELSE DO I CHECK OR NEED TO START???? PLEASE ANY HELP
OK i fiddled around and i got everything too work with a little giggle of the ignition switch but it wont when the car is on...Did i fry it??? I was reading and is there an electrical only portion of the ignition switch that can be changed, at a cheaper price??
