MSD Dumbness
the car: 1970T
Engine: 2.2L Dizzy: Marelli Coil: MSD Blaster Old CDI: Bosch Questions: 1) The old 3 pin connector into the bottom of the bosch box, is the red in the middle of the connector switched power or constant power? 2) if that red wire is switched power, where should i pick up constant power with the "heavy red" wire? 3) do i use the white wire to pick up the spade near the cap on the dizzy?? i have searched thru most of the archives, but i can't find answers to these specific questions. Thanks, Joe |
you need to run a wire to the batery or try one of the fuses in the engine bay
check this thread: http://forums.pelicanparts.com/showthread.php?s=&threadid=231159&highlight=msd+ig nition |
...thanks, but didn't really answer my question
1- CDI red wire is switch power.
2-There is a power lug at rear of electronics shelf where constant 12 v power is availablke. I'd put the MSD connection here. Much easier than running to starter. 3-white wire goes to dizzy lug which goes to points. You will probably need the tach adapter to get yopur tach working. Good luck. |
had the tach rebuilt to be compatible with the MSD unit THANKS VERY MUCH!!!
Joe |
MSD sells a tach adaptor. The power wire should come from the battery not a fuse panel and the MSD unit needs to be grounded.
Joe |
with the old original wiring harness, there was a braided ground that went to the base of the dizzy, and with the MSD, there is just one big ground wire that i bolted to the chasis, do i need to be worrying about re-grounding the dizzy???
car starts and runs, but still rough due to dizzy being off and carbs needing tuned, but still no tach worky, black and purple wire straight into msd box on the tach spade. tach was rebuilt with new guts which include internal tach adapter, my only guess is a short in the line to the tach, but i had continuity...so i'm confused...
| All times are GMT -8. The time now is 04:42 PM. |
