Front end alignment needed near Boston, MA
I'm looking for a good alignment shop in greater boston area to check the front end of my 84 Carrera. Anyone got recommendations for me?
Thanks in advance. |
http://www.autobahnperformance.com/index.htm
Independant shop located in Peabody on Rt 1 South; Porsche + Audi specialists. I had my 83SC aligned at Direct Tire in Peabody when I purchased new tires. While competent, they don't see too many older Porsches, and needed to be sure the appropriate tech was working that day. I would recommend a Porsche specialist who works on these cars day in and day out. Autobahn sets up race cars as well as daily drivers, and can do corner balancing. I will be taking my car there in the spring. |
I agree, Rick, the owner is a good guy and knows his stuff
If you only need your front alignment checked, any tire place with an alignment rack can do that along with a comprehensive computer printout of where your alignment stands.
Cheers, Joe |
Thanks for the tip guys. I had it done there and they did a great job. Rick was very nice as Bill mentioned, took the time to take some pictures of other small issues I should address with the car, but didn't put a hard sell on me at the same time. I'll definitely return to them for other work.
Doing the front only is a waste of time and effort. These cars require four-wheel alignment and corner balance. The setting on each corner affects it's diagonal counterpart. Spend the time and/or money to do the full alignment, you will regret it if you don't.
| All times are GMT -8. The time now is 05:57 AM. |
