450knotOffice's Avatar
Unhappy High Beams come on randomly
About a month ago I started noticing that my high beams would come on if I just very lightly touched the turn signal/high beam stalk, say for example when turning on my blinker. What a pain in the arse. Irritating as heck for me and no doubt the drivers in front of me as they think I'm flashing them for no valid reason.
Have any of you guys experienced this and if so, is it a simple fix or do I need a replacement turn signal/high beam stalk assembly?
Old 02-07-2006, 06:47 PM
syncroid's Avatar
Hey Scott, Thats a really common problem. Your Hi/Low beam/ turn signal switch is failing. The replacement part # is 911 613 305 01
I'm sure our host here sells them. Not a real pain to replace. Takes about an hour if you're a first timer.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 02-07-2006, 06:50 PM
Its a very easy fix- you may not need a new switch yet. I went through this a year ago.
You just need to 'reshape' a contact slightly (unless the thing is totally fried- in which case you may need to replace). No need to remove the switch to fix the contact.
I remember a couple of pretty big threads on the issue... will try & search them out for you.
Headlight dimmer repair?
Old 02-07-2006, 06:54 PM
don911's Avatar
I had the same problem. My cheap fix when it first started was folding some paper and inserting in the space behind the turn signal stock. This rendered the high beams useless except for pull flash.
This worked for a couple years until the contacts wore out too much. Finally replaced the turn signal switch.
I've read where people have taken the switch apart and did something with the contact but as long as I had to remove the thing, I decided to replace it.
It's a pretty easy job. The part is just a little expensive.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
RFR RFR is offline
RFR's Avatar
Wow. I step away for a bit to help make dinner (an Indian Curry dish I make, yum) and when I come back you guys have flooded me with answers. Thanks guys!
I know I can always count on this community.
Old 02-07-2006, 07:23 PM
I just did this a couple of weeks ago (see the above links). Based on the advice I got from this board, I fixed the exact problem you are having. If you haven't already, install the Sucro (or similar) relays to prevent full voltage going through the switch.
Cheers,
Mike
2016 Porsche GTS Club Coupe (60th Anniversary)
2007 Porsche GT3; 2014 Porsche Cayman S
1981 Porsche 911 SC; 1988 Porsche 944 Turbo S - Silver Rose
2010 Audi Q7 TDI; 2002 Audi A6 4.2 ; 1971 El Camino; 1966 Chevelle SS 396/360 HP; Spec Miata racecar
Old 02-07-2006, 08:14 PM
Thanks Mike. The Sucro kit was the first of many, many repairs/mods I have done to this car since I got it 1 1/2 years ago.
Old 02-07-2006, 08:35 PM
