help from the electrical/fuse gods!
Short story, i had to rewire many wires inside trunk when they burnt/fused together. Wipers woudlnt work unless the ground was actually touching wiper chasis...Ok, now yesterday i screwed up and took the car for a test run and a crow bar magicaly touched the hood and another point inside the trunk(fusebox?) and blew out my headlamps/wipers and rear brake lights with no fuses visiblely blown, except for black relays which i really cant tell i guess i open them up. What and where should i look if non of the 21 small fuses are blown? thks for ya'lls help
Old 02-07-2006, 10:57 AM
Banned but not out, yet..
RSBob's Avatar
Including the model and year in a signature might help you get responses. 65 911? or GT3? see the confusion?
Old 02-07-2006, 11:56 AM
sorry about that......my car is a 83sc 911.....and i rechecked everything again and have found nothing.....by the way...when the crow bar inside the trunk had contact with the hood and i believe the fuse box i saw a spark come from it and a spark from my turn signal switch, when the lights went out in georgia.....or on my car......cheers damian
Old 02-08-2006, 01:04 AM
I'd probably start by pulling the fuse panel away from the fender even just to confirm wire condition.
set up a signature
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-08-2006, 11:20 PM
